Old 06-17-2012, 09:37 PM
W00dy W00dy is offline
Question Coolant in exhaust
I have A late 94 G10 Metro.
It started to have a loss of power (boggy) on my way home from work I pulled into a parking lot it was idling rough. I shut it off when i tried to restart it it wouldn't crank over all the way at first it would start to then lockup. After i got it restarted it runs rough and i have Coolant in exhaust.
Got the car new in 94 and it has never been overheated.
I did a rebuild on it in 2008 (30 to 40K on it now) i used new head bolts proper torque and apex brand gasket set.
I think it must be the head gasket. ( have not tore into it yet )
Has anyone had one go bad that soon or are apex gaskets junk?
Any other things it could be?
Thanks, w00dy
Old 06-17-2012, 10:12 PM
DeltaP DeltaP is offline
Re: Coolant in exhaust
Never used Apex gaskets. Maybe the head or deck surface was less than perfect?
Old 06-17-2012, 10:46 PM
FishFind FishFind is offline
One Hot Shot
Woody do a COMPRESSION CHECK ON IT. I never used that gasket either. I use FELPRO.
Old 06-17-2012, 11:22 PM
danielsatur danielsatur is offline
A bad or plugged catalytic converter cold lead up to a bad Head or head gasket.
Old 06-18-2012, 12:35 AM
Thanks,
I'm going to pull the head off in a few days after i do a compression check hopefully the leak will be obvious.
I will check the cat allso.
Old 06-18-2012, 01:25 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
should be able to tell by looking at the plugs and see what cyl is leaking but yes it sounds like a head gasket. make sure you get new bolts when you replace the gasket
Old 06-18-2012, 04:46 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Here's the ONLY head gasket to use:
http://www.ebay.com/itm/270920776215...ht_1900wt_1194
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
The Following User Says Thank You to Woodie83 For This Useful Post:
W00dy (06-24-2012)
Old 06-23-2012, 02:55 PM
Greg_M Greg_M is offline
I've had a few cars that have had that problem. I used a gasket goop that was an aviation gasket sealer. It's clear but looks like it has copper dust in it. Always worked on hard to fix gasket problems. I don't bother using anything else after having used that a couple times. YMMV
Old 06-24-2012, 03:07 AM
Did a Compression test this is what I got.
Cylinder 1 = 195
Cylinder 2 = 210 wet with coolant*
Cylinder 3 = 200
I pulled the head off and found that the gasket had turned to some kind of silver mush.
So I ordered the head gasket that Woodie83 suggested.
Thanks to everyone who replyed.
Matte grey Gallardo LP560 with full Tubi Style exhaust system NM2255 Car Videos 0 06-17-2012 01:00 PM
Tags
coolant , exhaust , geo , metro
