Old 06-15-2012, 07:43 PM
jason616 jason616 is offline
05 trailblazer ac
my ac pump kicks on and off no matter what the rpms are at. the ac comes out warm and when i try to charge it the pressure goes up to overcharged and then goes to 0 because it kicks off every 10 seconds.
Old 06-15-2012, 09:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 05 trailblazer ac
Welcome to AF, you cannot just charge the system without knowing what is in there start with, it should be evacuated, leak tested and properly recharged.
Old 06-18-2012, 04:18 PM
how would i go about evacuating the system myself, do not want to take it into the shop
Old 06-18-2012, 04:24 PM
also my check engine light use to come on and off randomly, now it is on and stays on when i take it in nothing shows and they say i have a blown fuse but after checking all fuses all are good.
Old 06-19-2012, 12:26 PM
A990 racer
If the cel light is on there is a code, now the code reader may not work because the cigar liter/courtesy lite fuse operates the power to the scanner. You cannot evac the a/c without the proper equipment and backround.
The Following User Says Thank You to maxwedge For This Useful Post:
jason616 (06-19-2012)
