Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-15-2012, 11:29 AM   #1
65mustanggal
65 mustang convertible-did i burn the engine?
Greetings! First time user, hope to get some thoughts before I tow my car into the shop! Battery was dead, got a new one. Car won't start!! I hear the click of starter and nothing else. I have had the car for 9 years, I always check oil and transmission fluid because it does leak and i only use the car about once every 2-3 months.And my battery typically goes out. Last time it started and went just fine. I put it in the garage, turned it off. Turned it back on and it was running then it just stopped. My heart sank....so what should I expect to be checked first when I take it in to an auto mechanic? 65mustanggal
65mustanggal is offline   Reply With Quote
Old 08-03-2012, 04:43 PM   #2
Mohave
Mohave's Avatar
Re: 65 mustang convertible-did i burn the engine?
Your post is a little confusing and I am assuming the car ran fine and just died the last time you used it, but that it died and would not start. Now you are trying to get it running again and the starter just clicks.
Were you hearing the starter click or the starter relay? The first thing I would check would be the relay on the side of the fender as it can click. I would short across the relay to see if the starter cranks the engine. I would also start there to trace voltage at the two threaded posts on the relay. Check to make sure it is working correctly from a wiring diagram.
i would also check all connections between the battery and the starter for resistance and clean them. I would also check the ground straps for their ability to conduct electricty.
Mohave is offline   Reply With Quote
01 3.8L mustang convertible. what is the best way to get more horse power/torque while still maitaining or added gas mileage? bigd505 Performance 3 06-22-2011 12:43 PM
93 Mustang to 87 Mustang 4cyl Engine Swap chronomafia Performance 12 11-21-2010 03:17 PM
First car in the US ComingToAmerica Car Buying Q & A 11 06-17-2010 07:55 PM
1990 Mustang convertible engine andyfrigge Mustang Talk 1 05-25-2003 01:00 AM
people who did the det swap or any swap - what did u do with the stock engine? jared240sx 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 09-19-2002 12:20 PM
