Old 06-13-2012, 03:16 PM
philkb philkb is offline
Instrument cluster crazy
The instrument cluster on our 1999 Winstar is almost unuseable and the tach pointer is partially broken off fron getting jammed. Hittiing bumps and hitting the dash above the cluster will sometimes restore it temporarily or make it worse. Has anyone ever figured out where the poor connectin is? Many years ago I read about others having this problem and no one had figured it out back then (2007?)
Phil
Old 06-14-2012, 07:51 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Instrument cluster crazy
Hi Phil,
I remember reading somewhere that the bad solder was at the back of the instrument cluster and should apply for both the speedometer and tachometer, however I can't be sure which one is the exact one, you might want to try searching the forum for "bouncy speedometer", I remember that's the string I used.
I'll see if I can find the post I'm talking about.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
1993 base cluster to UB3 Upgrade?? Laprecio Cutlass Series 0 09-15-2009 12:10 AM
2001 Passat Instrument Cluster Ryannables '97+ 1 06-15-2009 09:10 PM
crazy instrument cluster SOUTH,TXRBS 2nd Gen 00-05 2 01-13-2009 03:50 PM
Instrument Cluster Panel mezzo-soprano SC/SL/SW 2 10-10-2003 01:09 AM
Instrument cluster? redvalkrie Cosmetics 78 01-07-2002 07:59 PM
