Go Back   Automotive Forums Car Chat > Chevrolet > Colorado
Old 06-13-2012, 03:20 AM
juwigley juwigley is offline
Can't get signal on my radio
Ever since I purchased my truck I can only get on station on my radio. I have tried everything that I know of to fix the problem, does anyone have the same problem or know how to fix it. It is getting really annoying.
Thanks
Justin
Old 06-13-2012, 08:12 AM
Tech II Tech II is offline
Re: Can't get signal on my radio
Could be a bad antenna or the antenna is not connected to the radio, or in some cases, there may be a joint in the cable between the radio and the antenna that came loose......this happens on AM and FM?
Old 06-13-2012, 10:49 AM
danielsatur danielsatur is offline
How about internet radio with smart phone + aux jacks!
Old 06-14-2012, 12:25 AM
tried all of that its odd because when the radio is out of the housing in the dash it works fine // also it is on both am and fm
Old 06-14-2012, 04:20 AM
phillipshaw phillipshaw is offline
How about on i phone? you can use it.
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Old 06-14-2012, 09:39 AM
If you pull the radio out of the dash, and then you have stations, but put it back in and lose the stations, you have a bad antenna connection......when you push the receiver back in, you are moving that antenna cable......it is either flexing the connection at the back of the radio or it is flexing a connector in the cable or you have a bad antenna cable, possible break that opens when the cable is flexed....
Can't Get Unlock Code For Radio seberg4 Cars in General 1 06-19-2008 11:20 AM
Installing a Sirius Radio - remove radio to get to the antenna wire ron h CR-V 1 03-22-2007 01:19 PM
05 xterra owner who can't get his stock radio out! klz168 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 11-04-2005 03:32 PM
can't get my picture (avatar) to work...someone wanna help me please?? BigKP COMPLETELY off-topic 3 07-15-2001 12:32 AM
