Old 06-03-2003, 10:51 PM
CivicSiR7's Avatar
CivicSiR7 CivicSiR7 is offline
Question 93 Civic Si won't start???
I purchased a 93 Si from an old couple. After a few months of having it, it didn't crank one day. I thought it was not having power so I jump start it and it didn't start. So next I thought it was the starter. Replaced it with one off my other civic I had. It still didn't work. I doubled check even triple check everything from the ECU codes (which there was no codes throwing at all), ground wires, wires to starter, fuses in engine bay, and in the car. Car still won't crank! AHHH! Hurting my head just thinking about it. I even tried to jump start it. But the odd thing is what my dad told me to do is, he told me to push start it. It worked, but when I shut the car off and try to crank it, it did the same thing NOTHING. But while I was driving around the block, it kinda sputtered like it wanted to shut off. Have any of you fellas ran into something like this?
Old 06-04-2003, 01:13 AM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
It sounds like your battery isn't holding a charge. I don't really understand this part, but it's something i've noticed from prior experience (someone correct me if i'm wrong - there could've been other things that contributed to this):
When you start your car, it takes power from the battery (duh). When you jump a car, it feeds power to the battery (duh). If the battery is completely dead, no current can travel.
Like i said, i'm not sure if that's the answer, just something i noticed on my car awhile back, but if you've got another vic (like the one you got the starter from), and you know the battery works, just swap it in and try it. Can't hurt.
Actually, as I think more about this, I think i've got it backwards... in my situation, i think i couldn't pop the clutch to make it start, but i could jump it.... I don't know =)
Just try the battery thing haha. Probably is wrong, but it'll only take 5 minutes to do...
Old 06-04-2003, 02:14 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I think try the battery is a good place to start. I had a friend with a CRX who's car acted like that once. I think it was the battery. Could have been the alternator, it was a while ago. But if the battery is hella dead, it wont hold a charge, or the alternator is broke and wont recharge it, or both. HX is right though, it's really quick to check and rule out those possibilities.
Old 06-04-2003, 05:50 AM
project92si project92si is offline
civic wont start...
i've run across this problem many times.....in most cases, acrua's and honda's ignition coil goes bad....the car cranks but doesnt start....did you try testing if there's any spark going to the spark plugs??? if not, i can guarantee it's something to do with the distributor and most times its the internal ignition coil... check for spark..hope it helps..laters
Old 06-04-2003, 05:59 PM
CivicSiR7's Avatar
Question
Well I'm at work right now guys, thanks for the the replys and suggestions. Not to confuse anybody, car doesn't crank or turnover. Earlier this morning I've tried to crank it again and nothing, no sound. I can only get it to crank or get the engine started by push starting it. Jump starting doesn't even work at all. I haven't checked the spark plugs or distributor yet, but I'll do it when I get home. Someone suggested that it could be the main relay, can it? Keep the replies coming guys!
Old 06-05-2003, 10:04 PM
CivicSiR7's Avatar
OK guys thanks for the replys, I've found what the problem was. It was the clutch switch! Damn how was I STUPID! Not to check. Now its running. Thanks, again for giving me suggestions on whats wrong.
Old 06-05-2003, 10:26 PM
4bngr 4bngr is offline
Send a message via AIM to 4bngr
Don't worry, it happened to me with my SVT Focus. It just shatttered into a million pieces one day.
Judge not, lest you be judged first
Old 06-06-2003, 04:54 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
4bngr is absolutely right on this one, your ignition coil is out....but it would be best to check that other stuff first cause i used to make the bad mistake of thinking it was one thing and replacing it and the problem still existed, but i think it will be your coil
Old 06-06-2003, 04:56 PM
well shit i guess if i had finished reading all the replies i might not be a day late and a dollar short on the answer huh...........boy i feel stupid
Old 06-06-2003, 05:04 PM
Honda God
It's all good, it happens to the best of us, at one point or another
Old 06-09-2003, 03:38 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
excuse me, but what the hell is a cluch switch?
Old 06-09-2003, 10:08 PM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
uhh.... when you start your car you have to push in the cluth first. Well if the switch breaks, the car doesnt know that your pushing the clutch so it wont try to start. You can actually get a bypass though.. My friend has his integra like that. He can start it without pushing the clutch at all.
1997 Integra GSR and 1992 Civic LX
Old 06-10-2003, 10:37 AM
jeffseby's Avatar
damn im an idiot, i should have known that, thanks for the info. That would be cool to start your car without the cluch pedal..
Old 06-10-2003, 02:13 PM
What kind of electrical work is involved in such a thing?
Old 06-11-2003, 03:47 PM
Honda God
am7787, stay in the wrx or suburu forum's if your gonna talk shit like that. Here's an idea for you. If you don't like civics, stay outta the civic forums
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
'00 Civic Won't Start w/ key, only remote start. Zhamnov '96-'00 Civic 1 07-22-2005 02:30 AM
Civic won't start raptornt '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 05-03-2004 07:14 PM
'93 Civic won't start when parked downhill gshockley '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-22-2003 01:30 AM
96 Honda Civic Won't Start - Battery Replaced - Is it my alarm? sam2cats '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 06-26-2003 07:37 PM
