Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 06-11-2012, 05:41 PM
suburbanstevie's Avatar
suburbanstevie suburbanstevie is offline
Olds, '99, 3.5L Coolant leak, Intake?
Hello all,
There is a whole bunch of threads about coolant leaks associated with intake manifolds and/or head gaskets. And I have been learning much about them from reading these thrreads, so thanks to all. With the help of this forum I was able to change a leaking cross-over pipe, then offered my own extensive suggestions about that repair (possibly scarring others from doing it themselves).
My problem, I've got a slow leak (will it ever end?!). And the mechanic just told me I need to change the lower intake manifold gasket for about $1000, And he specifically said the car has two manifolds. So I went home and studied my shop manuals (full GM set bought on Ebay), my car is the '99, 3.5L (not the 3.8L) and doesn't seem to have a "Lower" intake manifold. I am pretty sure there is only one (1) manifold, a big black plastic molded part.
Also... when under the car I can see coolant dripping from the forward area of the engine (starter, and forward block surfaces). But also dripping from the cross-beam just in front of the engine (the one I use to jack-up the car with the floor jack). This causes me to initially think the radiator is leaking, but it is totally dry and definitely not leaking.
My questions...
1. How is coolant getting on the forward beam? has anyone seen this before?
2. Am I correct, that I only have One intake manifold, with one set of gaskets?
3. Does the intake manifold have coolant in it? If not, where does the coolant come from?
Thanks,
1990 Chevy Suburban, 454 cu-In, R2500
(always parked in the garage)
1999 Oldsmobile Intrigue, 3.5L
1998 Windstar, 3.0L
1984 Toyota Pick-Up, 22R
99 LeSabre 3800 3.8 coolant leak? Head gasket? Lower intake gasket is leaking.HELP!! chubbygoatboy LeSabre 10 01-03-2010 08:49 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
New muffler/resonator pipe for '99 3.5L cheezwizard Intrigue 13 12-13-2006 06:50 PM
