Old 06-11-2012, 05:05 PM
3echo9 3echo9 is offline
1997 2.2L A/C help
Need some help..
A friend has a Cavalier that stopped cooling this summer. The car has roughly 85,000 (grandmas hand me down).
I hooked up gauges and found the low side to be sitting at 20psi and high side to about 5psi.
Visual inspection did not show any apparent oil leakage at the compressor. One thing I did find was what looked like a belt had shredded and gotten wedged behind the flywheel and the compressor body.
The clutch moves freely (didn't check the clutch before removing the debris) and I can hear fluid moving through the system.
Can anyone tell me if/how I can jump the compressor to see if the clutch will kick in?
Thanks
2005 Chevy Equinox LT 186,000 mi
2004 Buick LeSabre 200,860 mi
2011 Infinity G37x 103,000 mi
Old 06-11-2012, 07:54 PM
DeltaP DeltaP is offline
Re: 1997 2.2L A/C help
If the compressor doesnt engage and you said you found the remnants of a broken belt wrapped behind the clutch I'd check the clutch coil lead in wires and the a/c harness going to the clutch. The wiring might be broken. But if you're reading the guages correctly its out of refrigerant and you've got a leak and maybe a locked up compressor. I've never heard fluid in a system by turning the clutch. You are probably hearing a bad bearing!
Old 06-12-2012, 05:56 PM
Tech II Tech II is offline
You basically have no freon in the system......
Old 06-12-2012, 08:30 PM
brcidd's Avatar
brcidd brcidd is offline
You don't jumper 3 wire transducers-- your system will operate when it has 47 psi or more pressure in system- you have barely any refrigerant (freon is the trade name for the old refrigerant R-12 btw) in the system- and odds are great you have a shaft seal leak in compressor-
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-13-2012, 07:12 PM
I'm guessing the shaft seal is the culprit too. I went ahead and put a can of sealer/refrigerant in the system. I was happy to see that the system kicked in and cooled down to a constant 57 degrees F.
We'll keep an eye on it and if/when it no longer cools I'll replace the shaft seal now that I know the compressor is good.
97 2.2L timing confusion...help cavalier9777 Cavalier Problem Diagnosis 3 10-09-2010 11:34 PM
Any help would be great!!! 1997 Sunfire 2.2L Mikezayed Cavalier Problem Diagnosis 3 11-02-2009 07:19 PM
'99 2.2L p0301/idle help coldday Rodeo | Passport | MU 3 03-27-2009 01:38 AM
HELP locating EGR valve on a 1997 S10 2.2L 3rdgenfbodycrazy S-10 0 01-30-2006 07:28 PM
1996 green 2.2L Cavy kit??? help? SuPeR_fReAk Cavalier 5 07-02-2003 04:05 PM
