Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-11-2012, 04:57 PM
crazydriverz crazydriverz is offline
overheating only when in idle.
well i have this overheating problem while in idle. i can drive it anywhere but if i sit to long in traffic it overheats. so i checked all fuses that may be a problem. i changed the thermostat. however it blows good heat in the vehicle. i also changed the fan relay thats under the passenger headlamp. so i came to the conclusion it was the fan motor. i pulled it out and ran jumper wire from fan to battery. and the darn fan motor still works! im happy to know it works but where else could the problem be?
Old 06-11-2012, 06:08 PM
danielsatur danielsatur is offline
Re: overheating only when in idle.
1) What kinda fan, or fan clutch is being used?
2) Is there any road litter, bugs, or leafs blocking the air flow in front of radiator or air conditioning condenser?
3) Is there a shortage of coolant?
Make sure your fans are working proper when the air-cond is on.
Old 06-11-2012, 08:06 PM
its a electric fan.as for being filthy coil fins, its rather clean.coolant is up. its just not turning. i let it idle and watch for the fan to kick on while the hood is open and monitoring the heat gauge. i turn on the a/c to see if the fan comes on...and nothing. the fan is just not coming on. im stumped
Old 06-11-2012, 11:40 PM
That's a problem, the fans should turn on with AC.
Suspect a bad fan control module, relay, or sending unit.
What <year> <make> <model>
Caution - Don't run AC until fixed, and watch temp gauge,
If temp raise's turn Heat on high max.
Old 06-12-2012, 05:13 AM
Its a 2003 jeep grand cherokee with 4.0 li eng and 4*4.
Old 06-14-2012, 10:41 PM
Just to sum it all up. I got the problem solved. After hours of testing the electrical wires and hardnesses. I got tired and took back the brand spanking new fan relay...exchanged it. Replaced new part with a new part and BAM!!!! It worked. The first new part was faulty. Imagine that!!! Chow!!! VrROoOomMm
The Following User Says Thank You to crazydriverz For This Useful Post:
danielsatur (06-15-2012)
olds overheating only when pulling rosies97olds Aurora 4 12-09-2007 10:21 AM
Overheating only when I turn on the heater in Achieva 94 2.3L stangp Achieva 1 01-20-2007 08:18 PM
SR20 overheating just when idling HoosierDrifter Technical 8 02-11-2006 02:39 PM
Overheating Problem When Idle MichaelGFunkEra Accord/TSX/Accord Hybrid 4 02-14-2005 11:17 PM
Neon overheating only when driving!!!!!!! nieves50 Neon | Plymouth Neon 6 07-19-2004 11:52 AM
