Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 06-09-2012, 08:37 PM
corem corem is offline
Send a message via MSN to corem
trans fluid temp light
I have a 1998 with the 2.5ltre engine with automatic trans the trans temp light flash at times. Was wondering were to start with this. the fluid is clean and does not seem to get hot when driven. any ideas will help.
Old 06-11-2012, 10:14 AM
somick's Avatar
somick somick is offline
Re: trans fluid temp light
As far as I know there is fault code stored in the computer. You need to read it.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-11-2012, 06:36 PM
Thanks for this will check and post when I find out the code.
The Following User Says Thank You to corem For This Useful Post:
speediva (06-14-2012)
Old 06-14-2012, 06:54 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Keep us posted, and let us know what you finally do come up with to resolve the issue!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 08-03-2012, 06:54 PM
I found the code it says transmission torque converter solenoid. It runs great and shifts fine. I can find nothing unplugged or a bad connection. The only thing I have done was head gaskets and torque converter seal. Which I tried to keep from doing this but was not my choice.
Old 08-03-2012, 07:19 PM
matthew24u matthew24u is offline
If nothing is unplugged then since you had the trans out & they were unplugged at one time you should unplug them and check all pin connectors make sure there not bent and that they are making good contact. check all tour wiring make sure nothing is grounding out skinned or twisted together. the way you say it goes on & off I bet something is grounding in & out from time to time. just check and re-check the wires real good, if that all is okay then i would look at the temp sending unit and when it comes on and says its hot make sure it isn`t by checking temp manually with infared laser temp device or surface temp thermometer. P.S. take your time examining the wires peel back the tape or wire loom covers, even the smallest break in the wire coating will cause it to ground out and trigger that light. signed, always stuck in diagnostics!!
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 07:23 PM
Changed trans fluid in 98 Grand Caravan & added Trans X fluid to help leak,is this ok lindseylu Caravan | Voyager 6 01-06-2007 01:45 AM
Changed trans fluid in 98 Grand Caravan & added Trans X fluid to help leak,is this ok lindseylu Engineering/ Technical 3 01-06-2007 01:08 AM
2000 Impreza AT Fluid Temp Light ghite Impreza/9-2x/Outback Sport 1 12-04-2005 11:48 AM
problems w/94 tran fluid/error light aap787s Regal 3 06-29-2004 09:47 PM
