Old 06-08-2012, 06:33 PM
TimmyGTP02 TimmyGTP02 is offline
Clunk/Click in reverse
Hello all, I have a 2002 gtp and when putting my transmission in reverse it 99% of the time make a clunk/click noise. It doesn't do it when putting it in drive or anything else like that. I was told by a tire shop while getting new tires that my lower motor mount is worn pretty bad and needs replacing and that may be the reason for that sound. When I put it in reverse it doesn't slam or anything like that but it does move the transmission underneath a little bit. I had my wife shift it while I looked under the car to see it. Does anyone think that the motor mount is the culprit or is there something else that needs to be adressed? Thanks
Tim
Old 06-09-2012, 05:30 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Clunk/Click in reverse
I just replaced my lower mount and eliminated my clunk. If it's bad, replace it and go from there. I made a mistake and used an "Anchor" brand mount, it went bad almost immediately. I highly recommend OEM GM mounts. I replaced with The GM mount and all is good so far.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 06-09-2012, 12:19 PM
JonJon, were you able to replace it yourself? I've been told you need something to hold up the engine while you replace it and I only have a jack and a couple jackstands in my garage so not sure if it's something I should try to tackle.
Old 06-09-2012, 12:26 PM
I did replace it myself. I supported the trans and oil pan together with two 2X4's, the length of the two pans only. Unbolted the upper mounts "dogbones", remove the two bolts holding the mount down, then slowly lifted with floor jack under the 2x4's supporting the oil pans until there was clearance to remove my old mount and slid in the new one. The new one can only install one way and it's a good idea to dig all the dirt/crud out of the bracket before installing. The tricky part was lowering the engine onto the two mount studs but was able to maneuver the engine by myself and slowly lowered onto the new mount. There's a write-up for the trans mount on this website but not sure if there's one for the lower mount.
4 door sedan
No Mods
The Following User Says Thank You to JonJon68 For This Useful Post:
TimmyGTP02 (07-09-2012)
Old 06-09-2012, 10:02 PM
Okay thanks a ton. I will have to check it out and see if I can do it myself. I'm not exactly a master mechanic so I'll let you know how it goes.
Old 06-10-2012, 04:40 PM
I'm not very experienced in car repair myself either however, after doing the research, I was confident I could tackle this and it worked out well..Hope the same for you...
4 door sedan
No Mods
Old 06-10-2012, 05:00 PM
rickisrad rickisrad is offline
You can order a solid oe type mount that eliminates most of the failure rates. (if you get one from autozone it is a crap shoot, they mix up the two so you have to shake the mount to see if there is any fluid inside) I have used the anchor solid ones with no problems. The DEA brand solid engine mount part number is A2796 ( http://www.rockauto.com/catalog/rafr...441304-1650045 ). Also the solid trans mounts that the performance places sell can be bought in stores. Just get a 2002 Buick Regal trans mount and it will fit. The DEA HD mount is the way to go ( part # A2818HD http://www.rockauto.com/catalog/rafr...315370-3007715 ).
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
Old 06-10-2012, 05:04 PM
X2, I agree regarding the solid type mount. If and when I need to replace, I will purchase the solid mount...
4 door sedan
No Mods
Old 07-09-2012, 09:47 PM
Just out of curiosity can you guys tell me exactly where the mount is?
Old 07-10-2012, 01:08 PM
You can see and get to it through your passenger side wheel well. There's a U shaped bracket that fits over the top of the mount. Take your wheel off and you'll see it just below the pulley that's right on top of it.
4 door sedan
No Mods
Old 07-10-2012, 03:20 PM
Thanks a ton JonJon! Hopefully I can tackle this in the next few weeks. I'll let you guys know how it turns out. Again I appreciate everyones help, that's why I love this site
06 500 Max AC makes Clicking Noise FrankB43015 Five Hundred 0 06-08-2012 04:57 PM
