Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-06-2012, 11:02 AM
rogriney rogriney is offline
Pcm
How do a person test a powertrain control module to see if its faulty or good? My 1999 Ford Ranger doesn't even try to turn over when I try to start it. Battery is good, I got all lights and gages working when the key is turned on. All except the check engine light which went out months ago. Also the diagnostic link connector under the steering wheel doesn't work any more. The scan tool says link error when I plug into the diagnostic connector.
So again, is there anyway I can tell if the powertrain control module is bad?
Thanks,
Rog
Old 06-06-2012, 11:36 AM
FishFind FishFind is offline
One Hot Shot
Re: Pcm
Thanks,
Rog
You will have to take it to Ford and have them test it. Most shops don't even have what you need to test it.
1999 sable fans not coming on long enough, PCM, CCRM. cooling timetrax Sable 5 06-05-2015 08:52 PM
Got P0601 Internal Control Module Memory Checksum Error replace PCM or RE-Programm? gujju Caravan | Voyager 1 09-30-2010 11:01 PM
03 LS V6 with coil problems then PCM failure.. PCM module swappable? jasonsjwou LS | MKZ 4 07-29-2009 12:55 PM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
Reprograming PCM Jerry Baumgarner Engine and Transmission 1 01-30-2002 06:54 AM
Tags
control , diagnostic , module , pcm , powertrain
