Old 06-03-2003, 10:30 PM
chopstick1981 chopstick1981 is offline
terrible popping noise
i just replaced the driver's side drive axle on my parents plymouth voyager van, but now after three days of the van running just fine a problem has started: a loud pop can be heard when turning the vehicle, it only pops once but i can feel it through the floor board. please help!
Old 08-27-2003, 10:23 PM
Honor Honor is offline
Send a message via AIM to Honor
It's been a little since you posted this, so maybe it is solved, but I would check to make sure everything is fulling seated and properly greased. Also, are the joints still good, did you replace them? My experience with shafts and joints is that many times the universal/wobble joints (not sure what style is used) will pop loadly when wearing out, and usually with a lot of force. They only pop once though because then they have shifted into place and are tight. When you turn again, they have to shift into a different position, so it pops again.
Just my thoughts, could be something else, but it is a start point.
Honor
Old 02-05-2004, 12:50 PM
glemieux glemieux is offline
Re: terrible popping noise
sound to me like a bad ball joint
sounds to me like a bad ball joint
Old 02-25-2004, 01:51 AM
Anaudiophile Anaudiophile is offline
I'd get the axle shaft replaced again. Not all axle shafts fit one application on Chrysler minivans. You might have gotten one for a different application. Their lengths are slightly different depending on engine/trans. combinations. And/or you have a bad rebuilt axle shaft.
Old 04-04-2004, 11:25 AM
Three_Fingers Three_Fingers is offline
Ah, heh. OK. I know this one by heart.
The popping you're hearing is probably the inner CV joint breaking.
Always, when you're replacing the left drive axle-replace the front motor mount as well.
What made the axle go bad in the first place is the fron motor mount gets sloppy and allows the engine to lean too far with the torque, allowing the axle shaft to come out of the transmission too far and run on an extreme angle-destroying the inner CV joint almost instantly.
Replacing the front mount is easy.
Put a floor jack under the bottom edge of the trans bellhousing to support the weight and unbolt the mount from the plate on the engine-then unbolt it from the front frame and bend the lock tangs straight and drive the rubber bushing (big square thing) out of it-it'll be a royal pain because it'll be rusty and spring loaded (it stays in because it works like a big tension pin).
Pound the new one in the same way and bend the lock tangs over and reinstall the mount. No more busted axle shafts.
Hoping someone could help with a Pop in my Tranny. Germ305 Explorer | Explorer Sport Trac 0 08-07-2010 10:14 PM
popping noise when I turn steering wheel... phughes Grand Cherokee | Grand Cherokee SRT8 3 08-01-2010 04:15 PM
Terrible grinding noise of doom ronhl80 Rodeo | Passport | MU 4 02-08-2006 09:17 PM
do u ever hear a pop!! noise when... vtecntrldSI '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-01-2002 01:41 PM
popping noise on door close nldesai Maintenance 0 02-23-2002 01:38 PM
