Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 06-04-2012, 11:55 PM
phipps phipps is offline
2007 Ignition Key - Transponder?
We just purchased an 07 Aveo and only got on key. The car has remote entry built into the key, but I'm wondering if it is a transponder key. I'm trying to get another key made and am having problems finding one.
Old 06-05-2012, 08:15 AM
Tech II Tech II is offline
Re: 2007 Ignition Key - Transponder?
I'm confused.....is it a key with an attached key fob(keyless entry) or is this all built into the head of the key?
Look at your owner's manual......check out the theft system......If it is a PassLock system, then it is just a blank key.....
Old 06-05-2012, 10:06 AM
Yes, it has keyless entry and the fob is built into the head of the key, but I can't seem to find a definitive answer on whether there is also a transponder in the key.
I did check the owners manual but all it says is the vehicle may be equipped with an ignition disable.
Old 06-09-2012, 05:47 AM
mrmikey mrmikey is offline
Daughter just bought an '07 Wave, same car. If your key has a lock/unlock function, the key doesn't have a transponder and a regular, cheap normal key that costs $2.95 to have cut will work.
Apparently (from what I can figure) there were two kinds of ignitions for these cars, one with a transponder key and one without. The electronic lock/unlock key sets the ignition disable/alarm when you lock the doors whereas the transponder key enables the ignition whe you insert it.
Be aware, and I can't rememebr the exact scenario, but with the lock/unlock key, the doors will lock themselves after a certain time, 30 secs or so if the key is removed from the ignition. So don't take the key out and chuck it on the seat with the windows up :-)......Mike
Old 06-09-2012, 10:12 AM
Local Ace ordered a key blank and it works great. It turned out to not be a transponder key.
Thanks for the heads up on the auto lock. We've noticed that as well. All the more reason to make sure we had an extra key!
What Steps to add another Transponder Key Ididnt[BreAK]it Express | G Van 2 12-03-2013 11:42 AM
Ignition Lock removal Vito_1502 Explorer | Explorer Sport Trac 0 05-28-2011 08:31 PM
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 01:12 PM
Programming Transponder Key North_star Eclipse 2000+ 0 04-06-2010 07:20 PM
Anyone know anything about ignition switches? angel_iz378 Cobalt 3 09-08-2009 12:52 PM
