Old 06-04-2012, 08:17 PM
Amarc Amarc is offline
1995 Lesabre fails emission test
1995 Lesabre fails emission idle test. The idle HC limit is 200 and the car reads 272 and the idle CO limit is 1 and the car reds 2.9. all the other readings are fine. The car seems to idle smooth and runs fine. Any suggestions where I should start?
Old 06-04-2012, 09:36 PM
danielsatur danielsatur is offline
Re: 1995 Lesabre fails emission test
How many miles are on this car?
How's the fuel economy?
Is there a CEL on?
Is there a tune up history?
Start with a good Tune up:
1) New air filter, fuel filter, and PCV valve.
2) Clean MAF sensor, throttle body, and IAC.
3) New plugs, wires, and a H20 sensor.
4) Do a back pressure test on your catalytic converter.
The Following User Says Thank You to danielsatur For This Useful Post:
Amarc (06-11-2012)
Old 06-05-2012, 06:47 AM
Tech II Tech II is offline
Do as Danilesatur says, couldn't hurt......in this case, you really need a scan tool, because from the readings, this car is running rich.......I mean it could be something as simple as a dirty air filter.......on the other end, could be an O2 sensor, injector, MAF, etc. .......so do the simple thing, like a tuneup first.....
Of course, it all depends on where you live, too......in my state, if you fix this yourself, then go for a restest and fail, you are going to pay for another test.....if you go to a garage, they have a form they must fill out stating what the problem was and what the fix was....if you do go to a garage, make sure they have a gas analyzer to verify the fix.....
Old 06-05-2012, 11:51 AM
Make sure your car is at normal operating Temp before your inspection, a cold car is going to have poorer emission.
Old 06-11-2012, 01:46 PM
The car has 205000 Km. Did as you suggested. Cleaned MAP sensor. Replaced plugs (they had 45000 Km on them). Replaced air filter (it had 50000 Km) and replaced the O2 sensor (still had original there). The curb idle HC went from 272 to14 and the CO went from 2.90 to 0.00 Everything passed with flying colors. Thanks for the advice.
The Following User Says Thank You to Amarc For This Useful Post:
danielsatur (06-11-2012)
FAILED Emissions Test... 5point1 Engineering/ Technical 2 06-21-2004 08:16 PM
B16A Code 16 Failed Emissions Test Mojoe Let's get Technical! 3 05-07-2004 06:39 AM
1999 Mustang fails Emissions test in Texas SH-N-TX Mustang Talk 5 05-02-2004 01:13 PM
Failed Emissions test. mazda626-1 626/Capella/Capella Wagon 4 01-21-2004 04:57 PM
