Old 06-04-2012, 12:56 PM
joeshannallie joeshannallie is offline
A/C compressor clutch
I recently replaced the compressor on my 1999 Plymouth Grand Voyager SE. Was told that it was good. Now I can not get it to kick on no matter what I do. I tried the jumping of the relay by crossing 30 and 87 in the fuse and relay panel under the hood. Well when I do that the A/C clutch(not relay) fuse blows that is in the same box. I have not done anything else to it except that. I just wanted to be certain that the clutch would kick in and run. I have not added any oil or tried to do any R134 yet. I seem to think if I can not get the clutch to kick on then there is no way to make it take freon, Am I correct? My astro van was simple just cross the switch and no problem.
I even tried the low pressure switch and no luck. I guess it was the low pressure switch it had a round wire plug on it with 3 wires going to it and the actual switch had 3 prongs in it. It was near the alternator on a metal line that runs to the drier. Please reply soon with your thoughts or what to do.
Old 06-04-2012, 01:28 PM
mishalah's Avatar
mishalah mishalah is offline
Re: A/C compressor clutch
Why would you try to spin the compressor with no oil or freon in it???
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler
2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser
2008 Nissan Versa HB...wife's skateboard
1997 Jaguar XK8 convertible...best road car ever
1966 Mustang GT convertible...fully restored concourse show car
Old 06-04-2012, 01:58 PM
Reassurance that at least I know it will work when I go to do the rest! Now any clue on the fuse blowing that I described?
Old 06-04-2012, 02:38 PM
aleekat aleekat is offline
Was told that it was good. Probably isn't. If you can put 12volts directly to the clutch(engine off, key off) and nothing happens, it's obviously bad. Sounds like bad field coil. Just a guess.
Old 06-04-2012, 02:43 PM
I did not put 12 volts directly to it. Unless that is what happens when you cross the relay. But then the clutch fuse blows in the same box. I am reluctant to put 12 volts directly to the compressor. That is how I messed the first one up. I guess I could do it again and remove it as soon as the clutch kicks in. That is if it does kick in. Thanks for your help. What is a field coil?
Old 06-05-2012, 12:35 AM
mishalah's Avatar
Well, we all know fuses blowing is not normal and not good. There must be a short or grounded point somewhere in that circuit. I'm not sure what the voltage needed at the compressor switch is, but I thought it was 12V. The relay just acts as a slow buffer to keep the voltage from surging into that switch. But you should at least get the "click" from the clutch activating if the circuit doesn't shut down.
Do you have a good schematic?
Old 06-05-2012, 12:48 PM
I didn't say to get the compressor running. I said just to see if the clutch engages(clicks) with compressor NOT running.
Old 06-05-2012, 01:08 PM
plymouthsrock plymouthsrock is offline
Try jumping the relay with the clutch disconnected. If the fuse still blows, it's a wiring problem, or you're jumping the wrong terminals.
Old 06-05-2012, 01:25 PM
Ok I will go out and try that. I am jumping prong 87 and 30. That is what I found on Google to do. Is that correct?
Old 06-05-2012, 02:20 PM
Well the fuse in question does not pop when the compressor is not connected. It seems to be dead. I ran 12v straight to it and touched each prong in the connector on the compressor and nothing at all happens. When I do that on the old one the clutch kicks in but does not spin. So I guess it is dead.
Old 06-05-2012, 05:00 PM
If your engine is not running, all the clutch will do is click not spin. BTW how did you determine your old one was bad?
Old 06-06-2012, 03:12 AM
Well when the old one went bad, I ran 12v to it to see if would spin and it did and then I suppose I left the 12v on it to long and it started smoking near the clutch and now all it will do is the clutch like clicks in but will not spin when I put 12v to it. And now the one that I replaced it with will not do anything with 12v to it. I guess that is what I get for going to the junk yard and trusting someone.
Old 06-06-2012, 09:13 AM
If you feel like a road trip, pullapart.com. Got one in knoxville. They are worth the trip. You can not call them. Go up their website and you can search their inventory. It will give what they have and when it was placed on the lot. Prices are great. You're not paying for a part based on what it came off of. A compressor is priced the same whether it came from a mercedes or ford. You can get a warranty with it. You have to bring your own tools and remove the part yourself.
Old 06-06-2012, 10:53 AM
mishalah's Avatar
It's possible the pump has an internal switch that will not allow the clutch to engage at all if there is no oil in it. Protective stuff.
Old 06-06-2012, 11:24 AM
Yeah a guy at work told me about pullapart, That is about 80 miles from me. Great deals on parts if they are there when you get there. Just might head that way Saturday.
A/C Compressor Clutch Resistance jnuckols '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 05-30-2011 12:24 PM
Compressor clutch removal kharrell M Bodies 1 04-04-2004 07:37 PM
Compressor Clutch Removal kharrell General Discussion 0 03-20-2004 08:46 AM
A/C Compressor Clutch 46er2b Cherokee 0 11-22-2003 11:05 AM
Compressor clutch removal AllenW Blazer 0 09-01-2003 11:27 AM
