Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-01-2012, 04:03 PM
SOLSTER SOLSTER is offline
CV Boot???
Howdy all!
Think I messed up the CV Boots, see attached. This is the case on both sides of the front end
I think it was from driving on pavement in 4X4. I was in town, and spinning a turn, when I felt what I think was the front end binding. I noticed I was in 4 wheel, dumb mistake. I think this is what caused the problem.
So, what do I do now??? I called a local mechanic i trust, and he said the whole CV Boot will need to be replaced.
Is that true?
What cost should I expect, or find to be unreasonable?
Can I drive it 8 miles to that repair shop, or have it towed?
Other alternative ideas?
Bumbed for sure, but hope ya'll can help!
I'm a
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 06-01-2012, 06:04 PM
boritz's Avatar
boritz boritz is offline
Re: CV Boot???
Is that true?
Yes. [edit: we are talking 'cv boot' here and not 'cv joint' right? ]
The boot is there to keep water & grit out and grease in.
If your 8 miles is relatively clean and dry - then yes, drive it.
You could wrap the split with a plastic bag and tie it off with zip ties if you're worried.
If you are a competent DIYer you could fix it. You'll find various how-to's on the web. If not, go to the mechanic you trust
Last edited by boritz; 06-01-2012 at 09:23 PM. Reason: Clarify 'cv boot' not 'cv joint'
The Following User Says Thank You to boritz For This Useful Post:
SOLSTER (06-01-2012)
Old 06-04-2012, 09:16 AM
Re: CV Boot???
Just saw your eidt. Not sure about cv boot vs cv joint. See attched pic, that's about all I know. I discovered the problem backing up, and I heard loud metalic clunking noise. It did not make that noise going forward.
I'm trying to take it in today for repair. Anyone know about how much I might cost????
Getting the plugs changed out also.
The truck has been running great, I do regular maitenance onbit that i learned here on this forum
Shifter Boots and E-Brake boots WS-Enterprise Non-Performance 0 02-28-2006 11:12 PM
For Sale: Shift Boot and e-brake boot ManualMaxima Focus | C Max 0 03-20-2005 12:59 AM
Shift boot/E-brake boot purchase...where to buy? BigLou93se Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 07-21-2004 04:25 PM
replacing shifter boots and ebreak boots aznnutty 3000GT/Stealth 1 04-05-2004 11:53 AM
