Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 05-31-2012, 11:48 PM
JohnDD JohnDD is offline
Air Condition Clutch won't engage - 2007 CRV
My air conditioner clutch and solenoid were just replace on my CRV after the solenoid was diagnosed as open circuit. It was an expensive repair, since the compressor had to be removed, repaired and the refridgerant replaced. The mechanic said that Honda had provided a solenoid with a different part number than the original, suggesting that the original design has some issues.
Is the clutch (solenoid) failure a frequent issue with the Hondas? Are there any recalls/ out of warrenty repairs on this item?
My CRV has 106,000 Km.
Old 06-01-2012, 07:41 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Air Condition Clutch won't engage - 2007 CRV
Since your mechanic opened the system-- I'd say he now has a leak--which is the number one cause of mobile a/c failure- What keeps you from marching back to him? To fix it right...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-01-2012, 10:16 AM
The air conditioner works fine after the repair. The mechanic also replaced the O rings when he did the repair.
I have the old clutch and field coil that were replaced. The clutch bearing was rough, so probably would go later on and the field coil was open circuit. No sign of physical damage to the coil.
Old 06-01-2012, 04:40 PM
DeltaP DeltaP is offline
What's this "solenoid" you're talkin about?
Old 06-01-2012, 05:02 PM
Solenoid is probably wrong term.
It's the coil that activates the clutch in the compressor. It called "clutch coil", part number HON-38924-RWC-A01 on my invoice (and cost me $120.17).
Old 04-17-2014, 03:11 PM
BTW, Honda re-imbursed me for the total repair, since apparently this is a common fault and covered by an "extended warranty" or something.
206 Air Conditioning Carl.I 206 2 09-18-2014 03:19 PM
Air Condition Clutch won't engage properly JohnDD '96-'00 Civic 3 06-23-2011 01:18 PM
2003 Alero quits with air conditioning Stefphelps Alero 3 04-29-2009 08:16 AM
Air Conditioning clutch not engaging? baron1701 Aurora 12 08-01-2006 11:47 PM
Air conditioning compressor won't engage HotRodr56 C/K 3 04-11-2005 02:36 AM
