Old 05-31-2012, 10:13 PM
rqaform rqaform is offline
dirt inside tire(s)
bought a used full size van. Happened to check tire pressures on all four wheels. When disconnecting the gauge the valve cores leaked/hissed; put caps on quickly - was puzzled. Then the other day (year later) happened to ask my mechanic to change tire (because of flat) - when we looked inside the tire found fist full of shop dirt inside it - had fragments of paper price labels and dirt typically found on shop floors.... What gives - like sabotage - ???? this makes tires short lived? Tires are worn and need replacing for sure, but dirt content gives concern!? So for me, any time valve cores start leaking is sure sign of dirt inside tire, yes?
thanks for info....
PS have pics for the interested
Old 06-01-2012, 06:42 PM
vgames33 vgames33 is offline
Re: dirt inside tire(s)
Sometimes cores get old and start to leak. The dirt in there is likely a cause in your case, as it could have gotten stuck in the valve.
Labels and such in the tire was probably from some tire tech having a bad day and taking it out on a random customer. It shouldn't really change the life of the tire, aside from minor wear from being out of balance.
Old 06-02-2012, 03:01 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
It may not be malicious.. Such a malicious act would have made the tire difficult to balance, making a "comeback" likely and forcing that tech to re-do his work on his own time. I can't see a tech, even a vengeful one, setting himself up to re-do work without pay. To be fair though, people will do irrational things if angry.....
It might just have been a tech's laziness. Anyone who's worked with tires knows its time consuming to shake, tip or blow debris out of a tire, even when not on a rim, due to their shape.
It's possible the tire was sitting at a shop not on a rim and simply got some debris in it.Its easy enough if it was left sitting beside a garbage can.
The tech, not having a shop vac handy simply couldn't be bothered to scoop out or shake out the debris.
Anyways, there's little risk that it shortened the tire life, as noted above.
Old 06-02-2012, 03:57 PM
danielsatur danielsatur is offline
I wonder if the previous owner bought new or used tires!
Old 06-07-2012, 05:32 PM
thanks for info....
... when I said: (because of flat) ... I ,a little, misspoke; to amend reality: " because tire tread and steel belts separated from the casing while leaving the house" - but managed to keep the tire casing and tire pressure intact by limping home at 2 MPH and removing wheel with tire and taking to mechanic ..... tread and belts separated only at one spot; may be for about 1/8 tire circumference ... worth publishing pic on the forum? If so where?
Old 06-08-2012, 06:07 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool Re: dirt inside tire(s)
LMAO! Imagine the "vibe" if an old SNEAKER were left inside the tire mounted.
MY new X. LEATHER inside, hopefully dirt outside quadmd Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 08-04-2003 10:06 AM
