Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 05-30-2012, 07:46 PM
phipps phipps is offline
Check Timing Belt
Is there an "easy" way to get a look at the timing belt? We just bought an 07 Aveo with 60,000 miles and I'd like to take a look at the belt.
Old 05-31-2012, 04:10 PM
danielsatur danielsatur is offline
Re: Check Timing Belt
I would check the maintenance schedule 1st.
Is this an interference type engine?
I would assume it's the original belt, thus only having 60K miles.
Old 05-31-2012, 04:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
GM recomends inspecting the timing belt every 30k, you'll need to pull the top of the timing cover to do so.
Old 05-31-2012, 11:04 PM
Can the top cover be removed fairly easily? I looked at the directions in a Chiltons and it said you had to remove tire, splash guard and so on. Is there an easier way?
Old 06-01-2012, 08:03 AM
gmtech1's Avatar
You may not have to go through all of that since you are just removing the upper half. You'll just have to look and see if you can get to the upper bolts. I don't have one here to look at to say for sure.
Old 06-09-2012, 04:52 AM
mrmikey mrmikey is offline
If you can do the work yourself (if you're the least bit mechanically inclined) and have a normal set of tools I'd say change it, it's cheap insurance. It is an interference engine so a broken belt will cost a lot more bucks than the <$150 for a belt change. Not only that, it's hard to tell if the belts worn out, other than a missing tooth or some such obvious damage.
I just did my kids on her Pontiac Wave and it's not hard. Not only that but you can change the idler, tensioner and antifreeze while you're at it, waterpump too if you're so inclined ....Mike
Old 06-09-2012, 09:10 AM
Thanks Mike. I found detailed instructions and it definitely looks doable for me. My biggest issue is lack of a good workplace.
Old 06-09-2012, 02:55 PM
You're welcome.
One thing I forgot to mention if you do decide to do it yourself, get the correct waterpump wrench. You can do it with a set of waterpump pliers but the proper wrench is a lot easier. I think it's a 42mm but don't quote me on it find out for sure.
Last tip, once you line up all the timing marks and before you remove the old belt, get a paint marker or something similar and mark each sprocket and a correcponding tooth on the belt and ransfer the marks to the new belt.
That way it'll be easier to align all the marks when the cam sprockets move a bit, trust me....they will :-)......Mike
checking timing belt / campaign stickers Daddycat Rodeo | Passport | MU 5 06-10-2005 12:59 AM
Checking timing belt the_guy Galant 5 04-11-2005 07:32 PM
Timing belt tension spring's purpose AFTER belt install? Allen McCready Camry/Camry Hybrid/Vista 2 11-26-2004 10:42 PM
