Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 05-29-2012, 10:47 PM
ManPanda92 ManPanda92 is offline
Power Window Issues
Alright so I have been fidgeting far too long on this window, I need some help. The front passenger side window on my 2002 chrysler sebring does not work, I have pulled the door panel of and after hooking up the motor found that the motor does run. For some reason the switch when pushed up (to put the window up), has no response from the motor. Yet when pushed down the motor turns right on. The regulator seems to be in good shape, the motor seems to run okay and the switch seems to only want to turn the motor one direction (after having the motor removed from the regulator). By the way the switch on the drivers side door yields no response to the front or rear passsenger windows as well. Any advice on what the most likely problem here is would be greatly appreciated, thanks!
Old 06-01-2012, 01:32 AM
Re: Power Window Issues
I have an update if this makes it any easier, i have narrowed it down a bit, the motor and regulator are deffinately fine, for some reason the window only wants to go down I get no response from the motor when i try to put the window up.
Old 08-17-2012, 10:41 PM
jkmboler's Avatar
jkmboler jkmboler is offline
You have a broken wire in your door harness.
I would check the drivers door harness first.
Power window issues phantastic1 Caravan | Voyager 6 08-08-2005 08:14 PM
1998 ford taurus sho power window issue mattnday Taurus | Taurus Wagon 1 06-21-2005 06:54 AM
Power Window Issue Schmooozer Lumina 1 06-20-2005 05:04 PM
Weird Power Window issue ! HELP ! Please ddot Grand Cherokee | Grand Cherokee SRT8 1 05-29-2004 06:46 PM
2000 power window issues K8SJEEP Cherokee 3 04-12-2004 07:14 AM
