Old 05-26-2012, 07:59 PM
carkivey3 carkivey3 is offline
99 lesabre ignition/wiring problem?
my car will start everytime, however it will cut off and back on 2-3 times until cutting off completely. i can raise rpms while starting and it will continue to run but it is still cutting off/on. i am not getting a check engine light or a security light. i have already replaced ignition switch. with new sw and the old if i kept the key turned to start position it would run correctly except this will burn up my starter. i feel i am not getting codes because of a bad/faulty connection. the car thinks it is being told to turn off so no problem but when power comes back on the engine is still turning so it fires right back up. my chiltons does not have a great wiring diagram i could follow. if you know where i can get one or if you have seen this problem please let me know. thank you
Old 05-27-2012, 07:40 AM
DeltaP DeltaP is offline
Re: 99 lesabre ignition/wiring problem?
Does the check engine light stay on when you turn the key to 1st position,ignition on?
Old 05-27-2012, 07:04 PM
yes it does if you mean without trying to start it. just passed obd2 emissions 10 days ago so light and sensors should be ok
Old 05-27-2012, 10:09 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Have you checked fuel pressure?
Old 05-28-2012, 06:26 AM
45-60 psi.that was the first item i checked. then i thought no fuel should give me check engine lite. anyway fuel pressure good
Old 05-28-2012, 08:41 AM
what little is in my chiltons shows pink wire from ignition sw to pcm relay. was able to check at harness under dash. gets hot w/ key in run or start and stays hot even when engine fails
Old 05-28-2012, 08:48 AM
Tech II Tech II is offline
Remove the vac line to the f/p regulator and check for fuel in the line....
Also try, disconnecting the MAF sensor, and see if the vehicle will start...
Old 05-28-2012, 10:45 AM
it does start, everytime, but will cut off/on/off/on/off. i had already tried disconnecting maf.
Old 05-28-2012, 11:29 AM
enslow enslow is offline
Does it run normally as long as you keep your foot on the accelerator? This is soundling a little like the IAC valve.
Old 05-28-2012, 11:49 AM
when i raise rpms it still cuts off/on but with higher rpms it stays running because the rpms dont drop low enough when power is off momentarily to completely die before it gets power again. did u see the part about holding key in start position it does not cut off.
Old 05-28-2012, 02:04 PM
If you can get your hands on a scantool that records live data, this will be very useful to you. Hook up the scantool to record, start the car and hold the accelerator so the scantool can record the attempts to "cut out". When you download the information, you should be able to see what sensor is cutting out.
Also, with the scantool, monitor the misses to see if the miss is on one cylinder or on multiple cylinders.
If it's missing on multiple cylinders, the cause could be anything from plugs/wires to engine controls. Because the engine continues to run without actually stalling (although it does try to cut out), I believe your fuel pressure is good.
If the miss is on one cylinder, I'd suspect plugs, wires, or a faulty injector.
I am assuming you have checked the usual maintenance things like plugs and wires. I have heard of new plugs and wires failing badly.
Old 05-28-2012, 02:07 PM
Unless I'm mistaken, all this will do is use the starter to keep the engine running through the cut-outs so you won't notice the stumbles. I'm not convinced holding the key in the start position has any diagnostic value.
Old 05-28-2012, 02:51 PM
holding key is not for diagnostics. just for some reason it is keeps power where otherwise in run position it loses it. the starter cannot turn fast enough to keep engine running @ 800-100 rpms. i do not have access to a run time scantool but please realize i am not having firing problems. the ignition appears to be turning off and back on. if i were having firing problems the o2 sensors would pick that up and set off codes.
Old 05-28-2012, 03:45 PM
Not necessarily. If firing problems are not consequetive for more than a few cycle, it will not set a code, but will be detected with a scantool in a live data mode. Engine misses detected by a scantool can be due to many reasons that are not firing problems.
I would be very tempted to get a run-time scantool if you can afford one. You should be able to get a decent on for about $300-400, and may very well pay for itself by solving this one problem. The run-time scantool can monitor all engine parameters including voltage and rpm. You should detect the engine trying to cut out by seeing the rpm change, then look at the other data and see if there was another parameter that caused the rpm to change. I caught a bad MAF sensor this way, although it sounds like your MAF sensor is good.
As soon as we're talking about the pcm and problems with engine controls it's really hit and miss (excuse the pun) without a scantool.
Old 05-28-2012, 06:56 PM
worse case scenario happened. problem disappeared. i was checking grounds and was told ignition circuit ground is next to oil pressure sensor. i checked it and it was not loose and appeared fine. nixt time i tried to start it, everything was fine. i went back under while it was running and wiggled the dround but nothing happened. i cant go far in this car cause i dont trust it till problem found
DIC & Ignition Wiring Diagram ugsrich Grand Prix 1 12-14-2010 07:55 PM
1988 buick lesabre ignition problem...please help! sparcking LeSabre 7 10-27-2004 07:41 PM
Wiring Problems Engine keeps cranking without a key in ignition Tugger Explorer | Explorer Sport Trac 3 02-26-2004 10:02 AM
