Old 05-24-2012, 12:50 PM
tg5398 tg5398 is offline
'98 S-10 ALDL stopped working
I have a '98 S-10 and had the "service engine soon" light come on. (Not the first time it has.) Have a CEN-TECh OBD ll Code Reader to use on it. Always worked before, but the last time I put it on the truck it didn't. Tried it on a Dodge Dakota and it worked. Went back to my truck with it, and nothing. So, I'm not sure if unhooking the battery for awhile works or not, but it didn't work. The (CEL) check engine light never even goes out (After battery reset and restarting).
Anyone have any thoughts on this?
Hope I explained it right.
Old 05-24-2012, 01:20 PM
jdl jdl is offline
Re: '98 S-10 ALDL stopped working
At the data link connector, pin 16 is voltage, hot all the time, cigar fuse. Pins 4 and 5 are grounds. Check voltage and ground.
Old 05-24-2012, 04:31 PM
DeltaP DeltaP is offline
After you do that you need to check the diagnostic circuit. You may have a short to ground between the CEL light and PCM.
Old 07-02-2012, 07:41 AM
Sorry I haven't got back with you on this. Been very busy.
I need to know how the pins are numbered to do this check.
2008 KIA Spectra- Front Parking Lamps Not Working kingtut1980 Spectra | Cerato | Forte | Mentor 0 05-24-2012 11:21 AM
