Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-23-2012, 04:37 PM
chris peter chris peter is offline
Torque spec for front wheel hub 99 4x4 Tahoe
I have a howeling in the front end and the ABS lights on. So I need to replace the front wheel bearing assembly. My truck is a 1999 Tahoe 2 Dr 4x4 just need to know what the axle nut torque specification is. I don't want to guess these Timkin bearings are not cheap. Also any tips to doing the job would be appreciated.
Old 05-23-2012, 05:03 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Torque spec for front wheel hub 99 4x4 Tahoe
The axle nut is 165 lbs. ft. Its a pretty straight foreward job, the hubs may be stuck in the knuckle, so it may take a little "persuasion" to get them out.
Old 05-24-2012, 09:29 AM
j cAT j cAT is offline
I agree that the torque should be about 165 ft lbs. never use a air gun on the bearing/hub nut.
timken is what is recommended. I got my hubs at autozone .
removal in the rust belt is a problem. the hub is rusted into place you will need a chisel with a tapered edge to pry off the hub and using a good penitrating oil to help it slide off. the top stud is a little tough to remove. as the hub begins to come out you can then remove the top stud.
after the hub is removed clean the seating area for the hub , remove any loose/ rusted metal. you may need to replace the heat shield if you did not take care , in the hub removal process.
I used antiseize here in this area where the hub seats , to help in future removals.
do not use antiseize on the hub nut !
The first time I did this replacement I used some cheap hubs. 75.00 with 2 year warrantee. after 18 months I had a failure . the hubs came off very easy. I got my cash back then got the timkens.
before installing measure the sensor output voltage . rotate the hub by hand at a good rate you should get more than .4volts AC.............
Old 05-25-2012, 10:46 AM
Thanks for the information guy's I'm going to do on my next day off.
Torque Specs for Rear Wheel Hub? SilverOLDS Silhouette 0 02-26-2011 05:43 PM
torque spec for rear hub bolts sirdeeker Impala | Impala SS 1 04-26-2008 06:06 PM
Torque specs for rear hub jj86 Grand Prix 2 05-30-2006 11:20 PM
Torque spec for front shaft gland nut?? Derek S. Grand Cherokee | Grand Cherokee SRT8 0 10-26-2005 05:27 PM
Torque specs for 99 Hub Bearing okbye Grand AM 4 03-31-2005 12:51 AM
