Old 05-22-2012, 04:16 PM
scubacat scubacat is offline
Rear Subframe Insulators/Cushions/Mounts STUCK - 2002 3.8L with reinforcement bracket
Regarding the subframe mounts, I was able to change the front two, but the bottom of back left one (the top part) is literally jammed into the subframe. I tried prying it up from the sides, whacking it from underneath with a hammer (something started smoking?!?).. *nothing* will budge it. So I put the bottom part back and bolted it back up and left it alone.
Does anyone have ANY hints on how to press that thing out of the subframe? It looks like it's stuck into the bracket that was put on as part of the subframe recall. I had more than enough clearance above it so that it should have been able to move out of the hole. If this is too confusing I'll try to post some pics.
BTW - thanks to everyone for shaing so much valuable info on here. I went from hating this van to developing an "understanding" with it. Also, I asked the ford dealer where I bought the bushings if they could install the back 2 for me. They said it would be $469. I tried my best not to simultaneously laugh out loud and spit in the guy's face when he told me that.
Old thread about these bushings here: http://www.automotiveforums.com/vbul...d.php?t=763484
Old 05-25-2012, 02:20 PM
Windstartled Windstartled is offline
Re: Rear Subframe Insulators/Cushions/Mounts STUCK - 2002 3.8L with reinforcement bracket
As minivans go the Winnie is considered more DIY-friendly than average once you get to know it, that is once you've fixed enough problems and spent enough quality time lying underneath it to have developed a certain level of intimacy with it
That is the reason why dealership servicing is usually avoided once the warranty has expired. Rule of thumb, they charge double what you'll pay elsewhere.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Old 05-26-2012, 09:24 AM
I appreciate the input.
As for the bushings, I rented a large 3-jaw puller from oreilly's and bought a can of CRC freeze off. I'm about to go brave 90+degree heat to give it one more shot. (Hoping the heat plus the freeze spray will finally break this stupid thing loose.) If that doesn't work, I'm just going to live with the old ones.
Old 05-26-2012, 10:07 AM
12Ounce 12Ounce is offline
I've changed all mine ... it was a few years back. I don't remember any difficulties. I rarely drive in much slush or salt, so there was little rust to contend with. Good luck. Be careful with that flame!
Old 05-26-2012, 01:51 PM
Know what it is? It's that megastrength glue they used for the recall bracket. I took it off again this afternoon and looked more carefully at it. The rubber pries up no problem but the round metal part is completely stuck to the frame. Now I need to find something to dissolve that adhesive. Sheesh, what a pain. Looks like I'm going to have to give up on this one or find someone with an OA torch who won't charge me an arm and a leg.
2002 3.8L 171, 174 AFTER TBS along with other codes livewiregnat Windstar 4 02-28-2011 11:23 AM
Rear view mirror installation kafkacell Windstar 5 09-15-2010 09:38 PM
2002 3.8l...oil up by the injectors? 1Bradymichael Impala | Impala SS 3 09-07-2008 09:02 PM
2002 3.8L V6 - Clacking Noise FordBoss88 Caravan | Voyager 4 01-30-2007 11:44 PM
My 2002 3.8L V6 Kdizzle Mustang Talk 11 03-28-2004 11:28 PM
Tags
cushion , insulator , mount , stuck , subframe
