Old 05-21-2012, 09:00 AM
glennet glennet is offline
Power Steering - Air in system !!
Hello-
2001 Windstar. Had the high pressure line burst (long story) - anyway I replaced the high pressure line as well as the power steering pump. Now - I've tried EVERY method I found in the manual and online - can't get the air out. Persistent whine at about 1200 RPM and turning the wheel. At idle - the pump is as quiet as can be. I asked a mechanic buddy of mine - and he offered some vague theory about air being caught behind the check valve - and cracking the high pressure line at the rack while adding fluid to the reservoir. Sounds pretty messy and was hoping I might get a few more ideas here. Any ideas at this point welcome. BTW - this is the 2nd rebuilt pump I installed. When I couldn't get the air out the first time - I brought the 1st rebuilt back thinking it was bad. Oh well.
Old 05-21-2012, 10:37 AM
12Ounce 12Ounce is offline
Re: Power Steering - Air in system !!
Just be patient! It takes awhile, if you don't have the evacuate process the manufacturer uses.
I would keep the level on the "high side" ... and eventually all entrained air will work itself out ........
.... unless you have a leak on the low pressure side of the pump or rack!
Old 05-21-2012, 12:17 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
I have had LOTS of problems with reman pumps, sometimes have never had them get quiet. The best way I have found to get the air out of the system is a vacuum bleeder. I have modified a resivoir cap with a fitting on it and attatch a air power vacuum pump to it. You can use a hand pump, but its much more work. Drop the level in the p/s to about 1/2 to alow for fluid movement when the vacuum is applied, or you will just suck the fluid out.
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
