Old 05-19-2012, 07:41 AM
1996ctnc 1996ctnc is offline
1999 K3500 brake problem
I have hydro boost brakes and they are acting like something is wrong with either the power steering pump or the booster. It whines sometimes when I step on the pedal like I am low on fluid, but do not feel it in the steering and the pedal gets so hard to push it doesn't want to stop sometimes. It has had almost everything on the brake system replaced. I almost went through a store front today pulling into a parking spot. any suggestions? I would appriciate any input if anyone else has had this problem. Thanx
Old 05-19-2012, 09:00 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 1999 K3500 brake problem
Need to have the power steering pressure checked, its possible the pump is worn. If the pressure is ok, then the problem is most likely in the hydraboost unit.
Old 05-19-2012, 06:41 PM
I don't know how to, do I need to take it to a shop? or can I do it at home?
Old 05-19-2012, 11:10 PM
gmtech1's Avatar
Pressure test would need to be done at a shop. Not that hard, but special tools are needed. Pressure and flow can be measure with a power steering analyzer(thats the tool needed).
Old 01-20-2013, 02:18 PM
It's been a while, but I changed the power steering pump it helped a for a but the problem is back. The (ABS) light comes on now and stays on longer. I'm wondering if it could be a wheel speed sensor?
Old 01-20-2013, 06:08 PM
777stickman 777stickman is offline
Wondering about things is good. However this doesn't work well with the newer cars. The thing that does work well is a good diagnostic scan tool in the hands of a good mechanic. One thing you can try is pull the ABS fuse and see what happens. This will put the ABS lite on constantly, and will inhibit all ABS functions. But if it cures your brake issues, then you don't have to wonder anymore.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
1996ctnc (01-21-2013)
1999 F350 Brake Problems shooter_va F Series 4 03-28-2006 06:02 AM
1999 sunfire braking problem Tam30 General Discussions 19 01-03-2006 05:47 PM
1999 Malibu Brake Problems. davecl Malibu 7 10-25-2005 06:09 PM
1999 Intrigue braking problems grammat Intrigue 6 07-27-2005 10:38 PM
1999 abs brake problem tjgindy Grand Cherokee | Grand Cherokee SRT8 8 04-05-2005 01:53 PM
