Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-18-2012, 08:35 PM
la1's Avatar
la1 la1 is offline
4T65E Transmission Question
The trans is a 3 speed w/ od. So what is the difference between driving in 3rd and driving in " D ". For some strange reason I get a slight "bump" like a harsh shift same place every day at the same time. The car starts out in first, after about 5 or 6 feet, the bump. I keep going the car shifts to second later ok. Think it might be the PCS, not sure. Mostly does this starting out in the morning, has done it other times very rarly from a stop after driving ahile. If I take the selector out of "D" first thing in the morning and put it in 3rd all is ok....any ideas ?
Old 05-18-2012, 08:41 PM
Tech II Tech II is offline
Re: 4T65E Transmission Question
Just a matter of semantics....you have a four speed transmission....over drive is fourth gear....
Check fluid level and condition?
Scan the tranny for codes?
Old 05-18-2012, 10:45 PM
la1's Avatar
la1 la1 is offline
just did fluid and filter on the trans did not help. yeah, well outside of one uses OD the other does not.. stuff like torque converter lock up, PCS , was wondering if in 3rd and not OD the trans relies as much on the PCM and the MAP and MAF...ETC.
8th Gen Accord Questions jaimysessanna Accord/TSX/Accord Hybrid 1 05-21-2012 08:16 PM
