Go Back   Automotive Forums Car Chat > Mazda > 5 | Premacy
Old 05-17-2012, 06:48 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Mazda 5 tire question ?
My daughter has a 2009 Mazda 5 with 205/50/17 tires . She is in dire need of new tires which she can't afford at the moment . I found some used tires in the 215/50/17 size range and I am wondering if they will fit ? I know they are the proper rim size ( 17 " ) and will fit in that respect . My question is about properly fitting the stock alloy wheel width and also whether the larger size will cause a problem with rubbing , etc . ? These tires would be used as a short term solution to her problem and would be replaced soon with the proper size tires . Can anyone answer the question with a degree of certainty ?
" Sometimes I grow so tired "
Old 06-10-2012, 04:33 PM
Mx5guy Mx5guy is offline
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Re: Mazda 5 tire question ?
Yes you can, no problem the car will look even better this tires are a tiny bit fatter I have done this all the time with my Miatas and you are only talking one tire dimension up, no big deal I have gone from tire 195 to 215 and even 225 no problems. Good luck buddy go for them. Blessings! :-)
Winter tires - speed rating & downsizing Hello: A couple of questions for the forum. I have an 07 Camry LE. I am buying winter tires for her. I am jtmann Tires and Wheels 3 11-18-2010 09:07 AM
Kooky Tire Pressure Question RidingOnRailz Engineering/ Technical 13 02-02-2010 09:16 PM
Tire Substitution Question 195/50/16 for ? cjulia 323/Protegé/Familia/Etude/Allegro 1 12-10-2009 06:54 PM
1997 Mazda Protge Wheel and Tire Question matmandude007 323/Protegé/Familia/Etude/Allegro 1 11-30-2004 12:01 AM
