Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-17-2012, 01:04 PM
luisbe luisbe is offline
(SOLVED)1994 TP 3.8 Overheating in 2 minutes from cold, Help!
I've replaced the drain plug, filled up the radiator with proper coolant/antifreeze, turned on the engine then closed the cap to see the needle going fast to near the red mark. I turned off the engine and touched the cap with my finger but it was cold so I did the same with a hose, not hot.
Any ideas?
Thank you
Well, it seems the problem was not all circuit was filled. I did add more after a while running and now it is working normally (knock wood).
Old 05-17-2012, 08:19 PM
LMP's Avatar
LMP LMP is offline
Re: 1994 TP 3.8 Overheating in 2 minutes from cold, Help!
I'm sure it is OK
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 05-18-2012, 08:55 AM
Tech II Tech II is offline
Probably had an air problem....need to burp the system.....
Old 05-18-2012, 10:40 AM
It's working in normal temperature now. Thanks
1994 3.8 T-Bird LX - Steering Rack removal? bobski55 Thunderbird 2 07-07-2009 05:53 PM
95 Mustang 3.8 overheating dr_jones2u Mustang Problem Diagnosis 0 04-10-2009 10:39 AM
1994 3.8 Transport throwing alot of codes start_cleaning Trans Sport 1 10-09-2007 01:52 AM
95 sable 3.8 overheating problem rrclyoung Sable 6 08-05-2006 12:47 AM
1994, 3.8, No Power magoogle Trans Sport 7 11-27-2004 03:10 PM
