Old 05-17-2012, 12:31 PM
HansGruber HansGruber is offline
McLaren F1 flywheel question
Hello, I am doing a project on the McLaren F1 and have a question regarding the flywheel.
In a Road & Track article I found, Gordon Murray says the engine has no fly wheel.
http://www.roadandtrack.com/special-...n_f1_lm_page_2
"This is mainly due to lightweight reciprocating components but also because the engine has no flywheel and a 3-kg carbon-carbon clutch assembly."
But other sources state otherwise, saying it had a very light and minimal flywheel to reduce weight. I found this picture of the engine which shows what appears to be a flywheel.
Can someone please explain this to me. Thanks,
Old 05-17-2012, 06:42 PM
carbuilder2002 carbuilder2002 is offline
Re: McLaren F1 flywheel question
The term no flywheel strictly speaking is both correct and incorrect, correct in that what you see is basically just a ring gear for the starter pinion to engage, however saying that no matter how light there will inevitably be some flywheel effect due to the thickness of the toothed portion of the plate acting at a distance from the centre. As most will know the best flywheels have the mass at the periphery so it will act like a flywheel, albeit a very minimal one.
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
flywheel question 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-09-2003 10:58 PM
Aluminum flywheel questions DRCustom Engineering/ Technical 2 06-22-2002 01:48 PM
brake fad and flywheel question spy54 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-17-2002 03:01 PM
Another P10 flywheel question NA Racer Engine 2 03-12-2002 08:18 PM
