Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 05-15-2012, 04:20 PM
hcm1957 hcm1957 is offline
rough idle,low vaccum
I have a rebuilt 350 270 hp engine. Original quadra jet rebuilt and runs rough. Have low vaccum. Help
Old 05-15-2012, 06:45 PM
maxwedge maxwedge is offline
A990 racer
Re: rough idle,low vaccum
Wow pretty general. vacuum leaks obviously, valves too tight, timing wrong, for starters.
Old 05-15-2012, 06:52 PM
danielsatur danielsatur is offline
Do a smoke test to pinpoint any vacuum leaks.
Old 05-20-2012, 11:22 AM
Timing is on, Lifters are adjusted correctly and no vacuum leaks around intake.All vacuum lines are plugged. still have rough idle and can not adjust idle mixture screws
Old 05-20-2012, 01:35 PM
A990 racer
Compression test next. Or short out one wire at a time see if one cylinder does not change the engine speed or roughness.
Old 05-20-2012, 02:37 PM
DeltaP DeltaP is offline
My 2 cents: Faulty or incorrect PCV valve or hoses. Poor valve seating. Restricted idle passages. Bad coil. This is in addition to everything else mentioned.
Old 05-20-2012, 05:00 PM
Thanks for your 2 cents. All new hoses and pcv, heads where redone and running hei.
Corsa-b running rough and wanting to stall darrensailes Corsa/Barina 2 05-04-2016 12:46 PM
99 4.3 Rough Idle, Low Temp, Bad Gas Mileage dr_lee29 Problem Diagnosis 98 02-03-2016 06:51 PM
P0171 Rough idle uspres2020 Escort 8 04-28-2010 08:06 PM
2001 cherokee rough idle when hot mrrandyz Cherokee 0 03-22-2010 09:54 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
