Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 05-14-2012, 08:24 PM
cowboys2291 cowboys2291 is offline
Misfire-need some help
Ive got an 1989 Beretta with a 2.0 and have been having some trouble with a misfire. Car misfires at idle but is not a constant miss so I can't narrow it down to one cylinder. Will miss at cruising speeds and when accelerating if it hasn't warmed up all the way but goes away when warmed up. It wont set a C.E. light and no codes are stored. I have replaced and checked the following with no luck.
-Ignition control module
-Coils (swapped each old one with a new one and found no change)
-Plug wires
-Crank sensor
-Coolant temp sensor for ECM & pigtail connector
-Verified proper voltage at TPS sensor at idle
-I replaced the head gasket for a leak externally so I know no coolant is getting in cylinder. Plus head gasket leak wouldn't be noticed at cruising speeds. (unless it was dumping into cylinder)
If anyone has any idea it would be greatly appreciated.
got misfire and l need some help here guys! doodad Camaro Discussions 22 03-21-2006 10:08 AM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 09:03 AM
94 V6 mustang misfire #2 and #3 need some help?!?! NickFury36 Mustang Talk 0 01-16-2004 01:40 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 11:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 12:32 PM
