Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 05-14-2012, 03:52 PM
djamesdavino djamesdavino is offline
Dj
95' buick riviera 3.8L w/supercharger. Car runs extremely rough when cold started and won't stay running under a load,but after 15 min. she's OK. Had everything done to it, plugs,cap,rotor,wires,air filters, pcv valves, etc... Is this a common problem for this vehicle's year? I'm running out of money
Old 05-14-2012, 06:50 PM
maxwedge maxwedge is offline
A990 racer
Re: Dj
Scan it and look at coolant temp sensor inputs, fuel trims, ambient sensor inputs, no quick answer for this.
Old 05-14-2012, 07:15 PM
Tech II Tech II is offline
Re: Dj
Check the gasket between the super charger and the lower intake.....have seen the gaskets crack, and create a vac leak.....as the engine warms, and things expand, it could possibly seal.....
Best way to check this, is start the car cold, let it stabilize a few seconds, then spray carb cleaner all around the joint between the SC and the lower intake....if the idle changes, that is your problem....
Old 05-15-2012, 08:31 AM
Re: Dj
Thanks Max, I'll give it a try and I'll let you know. My friend is at work today,but will check it out hopefully tomorrow....
Old 05-15-2012, 08:33 AM
Re: Dj
Thanks to you also techII. I will let you know the outcome as soon as the vehicle becomes available..
