Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 05-13-2012, 08:59 PM
Sgregory Sgregory is offline
92 Cougar a/c compressor
Does anyone know how to rebuild the a/c compressor? Mine has no freon in it, there was a leak due to a missing schrader valve. The clutch only engages when I increase the psi to 40-45 using compressed air. (Also my a/c compressor has a broken connector, rigged it with wires to power it to see if it would work hence the results of it only engaging with high psi). I am a fairly experienced mechanic, I just don't know much about the a/c compressor. Any help will be greatly appreciated.
Old 05-13-2012, 10:14 PM
aleekat aleekat is offline
Re: 92 Cougar a/c compressor
Is it worth fixing if it's original? Seen a bunch on ebay, remans for under $100.
Old 05-13-2012, 10:18 PM
Everything under the hood is original except for my upper and lower control arms, had no access to a press to put ball joints in existing control arms.
Old 06-20-2012, 12:29 AM
Levithan9 Levithan9 is offline
Cool Re: 92 Cougar a/c compressor
It seems that you have a real Piece of S**t on your hands here. From what i've just read, your going to be better off replacing the damn compressor, installing new AC Lines, and please, for the love of God....pay someone to evac AND recharge this disaster. I can tell you now, if you decide to skimp here or there, your going to end up paying AT LEAST Double what it woud have cost you to do it right the 1st time.
I'm a ASE MAster Cert Tech. Trust me, I see this all the time.
Old 06-20-2012, 12:34 AM
phillipshaw phillipshaw is offline
Is that original?
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 04:45 PM
A/C compressor replacement jarl Trans Sport 5 12-12-2010 05:39 PM
Air Conditioner Compressor Cycling On and Off mafiadoller Silverado 6 06-06-2010 08:55 PM
3.5L V-7 Compressor Removal and Reinstallation krivasauto Intrigue 2 05-13-2010 09:45 PM
95 Lumina A/C Compressor Noise pete029 Lumina 1 05-19-2009 03:28 PM
