Old 05-13-2012, 05:25 PM
coonsanders coonsanders is offline
question about headlights
hi
i have a 2 door 2004 honda civic that has a non working right headlight..is there a way to tell if its an ele problem or the bulb?how much are new bulbs?thanks
coonsanders
Old 05-13-2012, 05:34 PM
danielsatur danielsatur is offline
Re: question about headlights
9 out of 10x's = burnt bulb
Check the owner's manual for a fuse on right front head light.
Caution - don't touch the new halogen light bulb, because the natural oils from your skin will cause the new bulb to burn out premature.
Old 05-13-2012, 05:46 PM
r they expensive?
coonsanders
Old 05-13-2012, 05:55 PM
It depends on the name & where you get it.
See www.autopartswharehouse.com , or www.partsgeek.com
If money is an issue, you might check your local bone yard for used parts.
Old 05-13-2012, 06:50 PM
hi
thanks 4 helping me..appreciate it much.
coonsanders
Old 05-13-2012, 10:00 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Assuming you have standard halogen capsule bulbs and not HID headlights, you can confirm you have power to the bulbs using a simple test light. You could also check the Civic forum here to determine if there is a common issue that causes the right headlight to fail, such as a connector that often becomes corroded, etc.
-Rod
Old 05-13-2012, 10:03 PM
thanks rod much..
coonsanders
Old 05-16-2012, 12:37 AM
vgames33 vgames33 is offline
Pull the bulb and look at it. Normal halogen bulbs often (not always) show burning of the glass or discoloring of the filament when they blow.
Question About Headlights (projectors) Fire_Leon '88 - '91 Civic | CRX | Wagon | Shuttlee 5 03-28-2006 03:36 PM
n00b question about headlights JustinGB Prism 1 02-25-2006 06:15 PM
Question about Headlight Bulbs RiCeMaN Accord/TSX/Accord Hybrid 2 06-09-2003 12:37 AM
question about headlight bulbs fergshonda Exterior | bodykits | Lighting 12 12-13-2001 08:31 PM
