Go Back   Automotive Forums Car Chat > Jeep > Commander | Patriot
Old 05-11-2012, 07:13 AM
cruiser69 cruiser69 is offline
Air Conditioning
I have a 2006 Commander 3.7 V6 that the air conditioning does not work. When I turn on the air the compressor is really noisy in the engine. Once turned off it is quiet again. No cold air blows out at all so I was wondering if the compressor is dead. I do not want to recharge the freon if the compressor does not work. How can you test this and how hard is it to replace. It looks like it is right on top of the engine.
Old 05-11-2012, 11:29 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Air Conditioning
From the description, I would say the the compressor is indeed dead. To check, install gauges and check the pressures, its is probably not building any high side and/or not pulling down the low side. With a failure like what it sounds like you have, the system will need to be flushed out and a filter should be installed.
Old 05-11-2012, 01:59 PM
How difficult is it to replace the compressor. Would I need to just flush the system, change compressor and recharge.
Old 05-11-2012, 03:19 PM
gmtech1's Avatar
If you had a major failure of the compressor, like you make it sound you did, Jeep recomends that you also replace the reciever/drier. The compressor is not too tough, need to have the system recovered before you start the repairs.
Old 05-11-2012, 03:28 PM
Do I need a shop to replace the receiver/dryer or can this be done also? Is it better to have a shop recover the system for me also?
95 3.1 Air Conditioning nato38 Grand AM 4 06-30-2010 07:23 AM
2000 SEL 3.8 air conditioning troubleshooting a/c Nox Windstar 6 06-20-2010 08:29 PM
2003 Alero quits with air conditioning Stefphelps Alero 3 04-29-2009 07:16 AM
Air conditioning recharge Sentax '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-24-2009 10:25 PM
