Old 05-10-2012, 06:54 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Bentley Speed 8
I spent a few hours to clean up the flashed over but low pin-holed resin body casting. Forming the brass fender louver panels and bending the actual louvers was a bit tedious, and I was a little surprised that I had to rework the right side recessed area of the body/fender so the panel could even be close to fitting semi-flush.
The chassis is all brass which I soldered together.
Old 05-10-2012, 07:34 PM
da_ashman's Avatar
Re: Bentley Speed 8
Looks great! except the screws on the base, but i presume these wont be on the final piece
Old 06-05-2012, 08:22 PM
Re: Bentley Speed 8
Yeah, those screws... I am working on them, they are not the most aggravating part of this kit. The instructions leave something to be desired, but are better than nothing. They tell you were the parts go, but not so much what order to assemble them. After studying the instructions and photos of the real car I decided to just dive in and make adjustments along the way as necessary.
I used Zero Paints for the Green, I also used their clear to seal it prior to decal application. So far I like the paint...
Old 06-06-2012, 03:42 AM
flhansen's Avatar
flhansen flhansen is offline
Re: Bentley Speed 8
Hi
I don't think the colour looks right, but it could be light? It looks more like the Aston Martin green for Le Mans than the Bentley green?
Here is a picture I found that more matches the real car.
Best regards
Flemming
Old 06-06-2012, 09:08 AM
Re: Bentley Speed 8
Take it up with Zero Paints, it is the Bentley Green. I think it could be the low light making it look off to you, (the picture looks different that the model to my eye). Overcast all day the last few days and I wasn't going to wait for sun to snap a photo before proceeding with decalling.
Old 06-06-2012, 10:50 AM
Re: Bentley Speed 8
The wheels/tires/brakes are made up of mostly PE in an aluminum rim with rubber tire and machined nut.
Old 06-07-2012, 09:04 AM
Re: Bentley Speed 8
The interior is done. I tried using the lead foil from a wine bottle as directed by the instructions for the seat belts this time. In some ways it is easier than tape (like I usually use) to work with, other ways a little more work. It looks a bit heavy in 1/43, but it also makes it pop. That might be a good thing once it is all inside the car.
Old 06-07-2012, 09:29 AM
icon_modeler icon_modeler is offline
Re: Bentley Speed 8
Looks great Mark!!!
Old 06-07-2012, 12:55 PM
123yokomo's Avatar
123yokomo 123yokomo is offline
Re: Bentley Speed 8
looks good so far!
Old 06-07-2012, 04:54 PM
Re: Bentley Speed 8
Decals and paint are done, onto final assembly…
Old 06-09-2012, 10:09 PM
Shunter's Avatar
Shunter Shunter is offline
Re: Bentley Speed 8
Looking good so far, a very cool car this was.
Cheers
Shayne
http://motorsportmodeller.blogspot.com.au/
Old 06-17-2012, 01:46 PM
DerXL's Avatar
DerXL DerXL is offline
Re: Bentley Speed 8
Looks absolutely perfect, especially considering the scale.
I only noticed the scale when you showed (and mentioned) the brass chassis.
Great work !
Axel
Visit my homepage for WIP's and galleries :
www.axelv.com
Bentley Speed 8 LM 2003 beaver63 Completed Projects / Gallery 10 10-11-2010 10:47 AM
bentley speed 8 lm-03 SCUDERIA-FERRARI Completed Projects / Gallery 18 02-19-2010 11:44 AM
Bentley Speed 8 2003 bikouros Completed Projects / Gallery 15 09-20-2007 08:30 PM
Bentley Speed 8 Body Color bikouros Car Modeling 5 12-06-2006 12:59 AM
Help! Cant find Bentley speed 8 images ashr Le Mans and Sports Car Road Racing 1 05-20-2003 10:20 AM
