Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-09-2012, 07:56 PM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
AC clutch not engaging
Vehicle: 02 4.7L Dodge quad cab 1500 sport, 4x2.
Issue: AC clutch not engaging.
TS done: Fuse checked OK, AC clutch relay OK, power through PDC check OK.
Question: I'm not sure what to check now, or how to check it.
Request direction.
Thank You.
08 Equinox LT
Old 05-09-2012, 08:53 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: AC clutch not engaging
I would check to see if you have voltage to the clutch at the clutch connector. If you do i would say you have a bad clutch.
The Following User Says Thank You to Scotty89 For This Useful Post:
nickledimed (05-09-2012)
Old 05-09-2012, 09:59 PM
FishFind FishFind is offline
One Hot Shot
Check that you have the proper level of refrigerant in it. If it is too low it will not engauge. If that is good You may be looking at a new compressor or clutch.
The Following User Says Thank You to FishFind For This Useful Post:
Old 05-09-2012, 10:07 PM
Additional information: I noticed when testing the relay when I connect power to pin 30 and ground to pin 87 I could hear and feel a click in the relay but when I put the relay back into the PDC and apply power I did not feel or hear the relay engage. Could this relay still be faulty?
Thanks again for all the help.
08 Equinox LT
Old 05-09-2012, 10:10 PM
I really don't think that the refrigerant is low, it was blowing nice and cold just before it quit working.
I will check this last due to the fact that I don't want to loose refrigerant by putting a gauge on it.
08 Equinox LT
Old 05-09-2012, 10:11 PM
I will check this next.
Thanks
08 Equinox LT
Old 05-10-2012, 01:29 PM
Thanks
I do not have power at the ac compressor.
08 Equinox LT
Old 05-10-2012, 07:19 PM
Hey guys,
I went ahead and replaced the relay..15 bucks.
The ac works now.
Thanks for the info.
08 Equinox LT
Old 05-10-2012, 08:49 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thanks for the update!!!
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
AC Clutch Not Engaging and Cooling Fans Not Working (I think) 1999montana Montana/Montana SV6 3 03-06-2008 09:16 AM
A/C compressor clutch not engaging chimp5150 Taurus | Taurus Wagon 10 05-29-2005 11:06 AM
a/c clutch not engaging freon psi ok HELP pamajoer Malibu 1 08-15-2004 03:18 PM
A/C clutch not engaging on my 90 4x4 ratedZX Pick-Up 2 06-30-2004 08:16 PM
'89 Park Ave. a/c clutch not engaging buck1 Park Avenue 2 05-26-2004 08:20 AM
