Old 05-04-2012, 06:03 PM
bmm341991 bmm341991 is offline
2001 grand prix gt 3800
I have a 2001 grand prix the sel is on i checked it and p0171 is the code bank 1 system too lean what could cause it and how to fix it i replaced the sparkplugs and wires maf air filter and a coil pack and catalatyic converter somebody help please it is almost time to got to emissions and it must be fixed
Old 05-04-2012, 06:22 PM
rickisrad rickisrad is offline
Re: 2001 grand prix gt 3800
could be a faulty injector leaking, you can switch the injector to another location and see if the lean condition moves.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-05-2012, 08:53 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Basically this means that your oxygen sensor in bank 1 "Pre Cat" detected a lean condition. Could be a number of issues or a bad 02 sensor causing your SES to activate.
Hopefully some others can weigh in and offer possible solutions.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 05-05-2012, 09:18 AM
Tech II Tech II is offline
Sorry, but I don't see how moving an injector will help in diagnosis of P0171? If it is an injector, the code still sets, so how does that help?
As Jonjon said, this means the pre O2 sensor is seeing a lean condition.....this could be caused by a number of things: vac leak, exhaust leak, bad MAF, bad/contaminated O2 sensor or O2 sensor wiring, low fuel pressure, fuel injector, etc.
2001 grand prix help needed wont pass emissions bagged98 Grand Prix 9 12-20-2011 05:49 PM
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
