Old 05-03-2012, 11:43 AM
ironhorse8 ironhorse8 is offline
2001 Blazer
For about two weeks, my Blazer would crank but not start on the first turn of the key. After a couple of tries it would start and as long as the engine was not off for more than a few hours, it would start again with no problem. While driving however, the engine would periodically "hitch" like it was missing a spark, or not getting any gas. As of last weekend, the engine will not catch at all, and a light on the dash shows "low fuel" even though the tank is almost full.
Spoke to a mechanic who (without looking at it) diagnosed a fuel pump problem at a cost of around $1,000. Is there any other problem which may cause this issue? I have very limited mechanical ability, and cannot pull the spark plugs to test them, as they seem to be buried in the lower half of the engine block.
Old 05-03-2012, 06:57 PM
viggy58 viggy58 is offline
Re: 2001 Blazer
sounds like the symptoms of a weak fuel pump. only way to know for sure is to rent a pressure gauge and check it yourself.
It's def an expensive job at a shop. MAKE SURE you get a delphi/ac delco pump!
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 05-04-2012, 09:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 Blazer
HARD STARTING CAN NOT BE DIAGNOSED JUST BY TALKING TO.
Only proper testing will tell you the story.
As said check fuel pressure when it is acting up.
A grand sound high for a fuel pump job.
I would find another repair shop for a second opinion.
MT
Old 05-04-2012, 10:02 AM
Jsaw Jsaw is offline
Re: 2001 Blazer
Yeah $1000 is definitely high for a fuel pump. My local Auto recycler has a fuel pump for $200, and thats a brand new aftermarket with a 1 year warranty. As for the job i find it hard to believe its $800 for labour.
-J
Old 05-06-2012, 06:06 PM
old_master's Avatar
Advisor/Moderator
Re: 2001 Blazer
$200 for an aftermarket??? You can buy 'em all day long on Amazon & eBay for under $100. They both have genuine AC Delco for around $180. Couple hours of work and it's done. Don't waste your time and money on aftermarket stuff when it comes to a fuel pump.
You have to know how it works,
to figure out why it doesn't.
Old 05-07-2012, 01:35 PM
mixin mixin is offline
Re: 2001 Blazer
^^^^^ WORD! ^^^^^
I put in an Airtex brand from AZ - it lasted about 20K miles and the fuel pump sender never worked right. I put in a Delco from Amazon like said above - truck runs awesome again and the fuel gauge works!
2001 Blazer slips into 4 wheel low drive, wont come out chapms Blazer 2 05-26-2005 09:39 PM
2001 Blazer door lock programming scvfan Blazer 3 03-10-2004 07:27 PM
2001 Blazer LS problem hiphopceo General Discussion 4 11-23-2003 01:56 PM
Lookin for power in 2001 blazer redblazinmarine Blazer 1 12-17-2002 10:34 AM
2001 blazer lift MacGuyver Blazer 3 09-20-2002 06:49 PM
