Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 05-02-2012, 06:36 PM
sxdc sxdc is offline
ABS Light Stays On.
I have a 2005 Pacifica with about 155k km. The ABS light was intermittently coming on but now stays on. I had it scanned for fault codes. It has a Left front sensor Circuit Failure code. The logical problem is the Lt front ABS sensor so I changed it and cleared the code. The light stayed on. Scanned it again and the same fault code is there, so the next logical problem is the tone ring which is part of the hub/bearing assy. So I changed it and cleared the code. The light stays on. The next thing to check is wiring or the actual ABS computer module. The wiring and connectors all look fine. Also, when I say we cleared the code, I mean we tried to clear the code. I had 3 separate places try to clear the code but it never cleared the light and always stayed on. The last place was the dealer where they used the actual Chrysler Scanner. Is it odd they couldn't clear the code? Shouldn't it clear and if there is still a problem it would show up again as it is driven? Would this indicate a wiring or circuit problem?
Any tips or insight would be appreciated.
Cheers
ABS light stays on on 96 Sunfire... paulpop72 General Discussions 14 04-12-2016 10:08 PM
ABS light stays on & 4WD light flickers????? Dougster Amigo 1 04-30-2007 06:12 PM
97 Cavalier EHT light and ABS light stay on Carol Overton Cavalier Problem Diagnosis 0 07-12-2005 12:10 PM
abs light stays on after brake change nadspot Grand Prix 2 10-01-2004 12:35 AM
Abs Light Stays On wvugrad92 Windstar 1 04-04-2004 03:26 PM
