Old 05-02-2012, 10:02 AM
Phlavor3 Phlavor3 is offline
2001 Ford Windstar /having some problem?
HI there,
I am having some problem with my 2001 Ford Windstar; the heater stop working and also there is noise of a clunck from the heater area coming through. I check the coolant and it was very low barley any there, I put some coolant fluid in it, but the heater still did not get fix. Now the van don't start and when I took a look at the coolant it is empty. What can I do to fix this. When I try to tun it on, and the light come on but it won't start. Please help me??Thanks!!!
Old 05-02-2012, 05:08 PM
phil-l phil-l is offline
Re: 2001 Ford Windstar /having some problem?
Sorry to hear of your problems. Sounds like several things are going on here...
The initial heater problem you mentioned is likely the blend door (which is a small door inside the ventilation system that controls where air flows). It's a fairly common problem - and is pretty easy to fix. Search for "blend door" on this forum for more info; there are also YouTube videos that nicely document the fix.
The sudden loss of coolant - and later failure to start - are more serious, and open up a whole range of potential issues. Some places to start:
- Do you see signs of coolant leaks under the van?
- Does the engine oil dip stick show any signs of water in the oil (rust, foam, etc.)?
- You say the engine doesn't start. Does the starter seem to be spinning the engine normally?
- I presume the "Check Engine" light is on. Do you know someone with an OBDII scanner who can use it to find out what the error code is? These scanners are now fairly affordable and common. Knowing the error code will help narrow further debugging.
I hope this is helpful to get you started!
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 05-04-2012, 09:14 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Welcome to the forum!!
If the oil dipstick is OK and you see no milky appearance oil, I would keep refilling the coolant reservoir; maybe the fluid level was so low that you still need more coolant in there.
The question is what happened to it? you might have problems with a faulty reservoir cap or something more complicated like Phil has said.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 05-05-2012, 01:05 AM
tempfixit tempfixit is offline
Does the engine turn over but does not start?? IF so do you have saprk??? Remove the air cleaner tube to the throttle body and spray a touch of starting fluid or carb cleaner into throttle body and see if engine runs then, if it does you have a fuel issue problem. If no run then check for spark issue.
Old 05-06-2012, 10:23 AM
mark_gober mark_gober is offline
If the engine doesn't turn over, remove the spark plugs and try to turn the engine over. I had an issue about a month ago that I had been losing coolant and one day I tried to start it and it wouldn't turn. You could hear the starter engaging, but the motor wouldn't turn. I obviously was very concerned at this point that the motor had seized.
I removed the front spark plugs and tried...same thing. I removed the rear ones and the rear cylinder closest to the driver was full of coolant and thus stopping the engine from rotating. I had a blown head gasket.
I did the repair myself for around $150. It took a few extra days because of the need to acquire new head bolts and my local parts store didn't have any.
Good luck.
Mark
2001 FORD Windstar Code 1309 Frank Brooks Windstar 8 05-28-2005 06:31 AM
2001 Ford Windstar Oil In Throttle Body BATMAN1966 Engineering/ Technical 0 01-07-2005 10:19 PM
using remote start--2001 ford windstar oligan General Discussion 1 08-27-2004 08:10 PM
keyless entry for 2001 Ford Windstar jbail General Discussion 1 04-01-2003 10:19 PM
