Old 05-01-2012, 10:08 PM
HibachiJeff HibachiJeff is offline
tamiya ts-83 question
on the spray can it is written must use "TS-14 black as an undercoat for best results" i don't have that and i can't find that anywhere . anyone know of a substitute?
Old 05-01-2012, 11:36 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: tamiya ts-83 question
I've never used the product, so I don't have any first hand experience, but from what I read (in Japanese), the spray might damage bare plastic, or come off with a masking tape. That sounds like the paint is some kind of hot lacquer (unlike the usual synthetic lacquer TS sprays) with weaker adhesion. When using a paint like this, I'd use Dupli-Color (or similar automotive spray). I know Dupli-Color gloss paint will damage plastic, but its primer doesn't, so I'd experiment with gray primer, then gloss black, followed by Tamiya TS-83.
Hiroaki Fukuda
Old 05-02-2012, 12:06 AM
thanks man i will try your recommendation.
how soon after it is covered in gloss black that i should use ts 83?
Old 05-08-2012, 01:57 PM
Vette Modeller Vette Modeller is offline
I've tried only one small experiment with TS-83 Silver and 84 Gold and was disappointed with the results. As suggested I did it over Tamiya Black then shortly later sprayed the metallics. It seems to provide a fairly tough and smooth surface but left a slightly mottled effect. If this is Tamiya's attempt to create an Alclad surface in a spray can it left me wanting to stick with Alclad. It is also a lot more expensive then the regular Tamiya synthetic lacquers , which I use a lot of. I'll experiment with it again but not anytime soon.
The Following User Says Thank You to Vette Modeller For This Useful Post:
lovegt40 (05-08-2012)
Old 05-08-2012, 02:38 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
any gloss black acrylic spray should do. avoid matte or semi-matte black though
olly olly oxen free
Tamiya TS spray question speeddemon92 Car Modeling 19 03-10-2008 07:26 PM
Tamiya TS-79 semi-gloss clear question zak78 Car Modeling 4 11-25-2007 07:51 PM
Tamiya TS-13 over Tamiya XF-1? Tikiman Car Modeling 9 11-11-2004 06:02 PM
what do you use to clean Tamiya TS paints from airbrush? COZMO6476 Car Modeling 1 07-12-2002 03:56 PM
Tamiya TS-42 MaxSE Car Modeling 3 05-15-2002 08:47 PM
