Old 05-01-2012, 12:15 PM
Dankim0 Dankim0 is offline
2001 taurus 3.0 code p0401
Im having trouble with this the dpfe sensor should have .9 volts on pin #1 12 volt ground on pin#2 and 5 volts on pin #3. I have 5.04 volts on pin #1 pluged in and unpluged I dont know where pin #1 gets its feed could it be a bad pcm? I need some help.I tested the egr it test ok I also tested the vac switch it test ok
Old 05-02-2012, 09:23 PM
tempfixit tempfixit is offline
Re: 2001 taurus 3.0 code p0401
To me it looks like the power is coming from PIN # 90 on the PCM which is the VREF, which goes to TPS, to the DPFE and to the Fuel Tank Pressure Sensor. I believe that should read 5 volts on #1. #2 should read 0volts and # 3 should read .5 to 4.5 volts.
Here is aa link that migh be helpful to you.
http://www.youtube.com/watch?v=CkgrM...oy4alB2WXJCIqA
2001 Ford Taurus 3.0 OHC SES Craigford Taurus | Taurus Wagon 11 11-12-2009 01:06 PM
1995 taurus 3.0 engine hercules Contour 2 10-13-2005 11:16 AM
98 taurus 3.0 litre coolant drain buckmeister Taurus | Taurus Wagon 1 12-08-2004 04:05 PM
1993 Ford Taurus 3.0 surging when cold?!!! AUTOUSA Taurus | Taurus Wagon 0 10-18-2004 09:30 PM
