Old 04-30-2012, 10:16 PM
Sunliner Sunliner is offline
AC not cold when idling-but otherwise cold
Have a 2006 trailblazer LS with the regular AC (not the digital or whatever it's called)
It's already pushing 90 some days down here....
So the AC will blow cold enough to freeze me out almost as long as the truck is moving even a little bit. Stopped for any length of time though, and it blows kind of warm-ish. Gets cold again as soon as we start going.
Wondah what's going on?
-Mike
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
I miss my '97 Blazer...
Old 05-01-2012, 11:11 AM
Tech II Tech II is offline
Re: AC not cold when idling-but otherwise cold
Clutch on the cooling fan?
Old 05-01-2012, 11:59 AM
danielsatur danielsatur is offline
Look in front of the air cond condenser for bugs and road litter!
Old 05-01-2012, 02:55 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Both TechII and danielsatur make good points, but I had to lean more toward TechII on this one, sounds typical of a fan clutch problem.
Old 08-29-2012, 02:28 PM
Surg Surg is offline
Jetwash out condenser and radiator if that's not it could be low on freon if not that compressor is goin out
Old 08-29-2012, 05:37 PM
Leave truck in park and rev the motor bet ya it gets colder cause pump is turning faster and the pump is getting weak it happened to the wife's Lexus what helps a little is running the recirculate option cools down 50 degree air instead of 90 degree air
heater blows cold when idling 1985jz Altima 1 11-26-2007 04:35 AM
Heater cold when idling JeepForever Grand Cherokee | Grand Cherokee SRT8 0 01-06-2006 12:03 PM
right side blinker does not work when the veh is cold torchous Camaro Discussions 1 04-22-2005 10:45 PM
High idle when cold temps outside/moving but ok when stopped jgtatl SC/SL/SW 3 10-30-2004 03:57 PM
'97 Camry - when cold fast idle not kicking in goretro77 Camry/Camry Hybrid/Vista 1 12-19-2003 09:16 PM
