Old 06-03-2003, 01:06 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Question adjusting the valves
how do i do it?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 06-03-2003, 01:17 PM
91civicDXdude's Avatar
make sure the car is cool. remove valve cover. set #1 cylinder at TDC.
use a wrench and a screwdriver to adjust the valves, you'll see what i mean. stick the feeler gauge in between the rocker arm and the valve, it should move with *slight* tension. once its set to teh proper size, hold the screwdriver still and tighen up the nut.
turn the engine 1/4 turn which should be TDC on #3. repeat.
firing order 1-3-4-2, go in that order
Old 06-03-2003, 02:13 PM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
hey check out my thread about the shopmanual, d/l it and it has all that including the clearances it should have.
Id rather be drifting...
Old 06-03-2003, 04:13 PM
Jay eS Iye's Avatar
i found my chiltons and it says .007-.009 (either that or .0007-.0009, i can't remember)
another question, if the valves have been clickin or whatever youw anna call the noise for almost a week, how much damage has been done? And how would i know if the valves have been warped from them.
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 02:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
Can you adjust the seat height in Intrigues? If so, where are the controls? hito Intrigue 2 07-25-2004 06:45 PM
99 G-Can you adjust the gain on the bose amp? Brian P Audio/Security 1 06-13-2002 10:36 AM
