3 timing chains in less then a year
My brother has an 02 cavalier OHV and we have replaced the timing chain 3 times since june of 2011. I changed it the first time and a shop has done it the other 2 times. Anyone know what might be causing this?
Re: 3 timing chains in less then a year
also tensioner was changed all 3 times
OEM or aftermarket parts. What is wrong with them to replace? stretched or broken????
Have the gears been replaced?? alignment. What did the dhop say?? warranty??? |
All the gear have been replaced twice. I don't know about the alignment there is no warranty because it is not defective parts. The shop said they could find the casue but it would take $$$$$$ which I don't have. Thanks |
When you did the repair did you make sure the alignment was proper?? Do you have a factory service manual for instructions?? I have not done the repair but from what I read alignment is very critical. Have you talked with a dealership about problem? Hopefully someone else with experience of the repair will comment. |
the last time I had it done was at the dealer cause the shop I used went out of business. The dealer said they would have to trouble shoot until they found the problem |
Which engine is it, 2.2 or 2.4??? Any odd noises before this happens?? Have you done a compression test once new timing chain is installed??? From what i gather this is a interference engine. Do the valves move freely???
Is this the Ecotec engine? I believe this is an interference engine....hard to believe the valves aren't bent when this happens....
I believe there was a TSB about this problem, stating that the cam and crank gears had to be replaced, along with a new chain and tensioner, and ALSO the oil nozzle had to be replaced.....I believe it has a larger opening....were ALL these parts replaced, including the nozzle? |
it is a 2.2 OHV not the Ecotec. all gears and tensioner was replaced with the chain. I was told that this was a noninterference engine. I will check with the dealer. the oil nozze was not replaced that I am aware of |
Is the chain oily or dry when it breaks???
ended up the oil pump was bad and and not oiling the chain properly
Congrats on finding the problem and thanks for posting fix.
