Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-24-2012, 08:28 AM
Steve J Steve J is offline
Need helping choosing fuel pump
My vehicle is a 1998 Chevy K1500 pickup with a Vortec 350 V8 5.7L engine. Recently the fuel pump went out and I'm not exactly sure what I should replace it with. To my understanding, I have to replace the fuel pump with a high pressure pump, but how do I know if the pump is good enough? Which brand should I get? If I want to replace just the pump and not buy the whole assembly, does the pump have to match the brand of what's in it?
Thanks
Old 04-24-2012, 09:58 AM
777stickman 777stickman is offline
Re: Need helping choosing fuel pump
It's best to go with the OEM AC-Delco Delphi pump that's matched to your VIN.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-24-2012, 10:11 AM
Ironic Ironic is offline
You can buy the whole assembly with the sender unit, but its not cheap. Done a little shopping around for you and found this: http://treperformance.com/i-6317754-...1987-1999.html
Are you 100% the fuel pump is bad? Its a mess of a job to get into, you may want to search youtube for a video that will give you a preview of what your going to get into.
Good Luck
Old 04-24-2012, 01:28 PM
Good Luck
The diagnosing that I've done is that there is no more buzzing sound when I try to start the truck (which won't start), and I checked after to see if maybe a fuse had blown but they all looked good to me. I've never changed a fuel pump before, but I've got a buddy that owes me one that said he'd do it for me if I got the pump.
Old 04-24-2012, 05:25 PM
There are two important things to check before you spend the money & effort replacing the pump assy.
1. Check for 12v on the grey wire at the fuel pump wiring connector coming from the chassis. This voltage should be present for 2 secs when the key is turned to the "run" position.
2. Check for a good ground signal on the black wire at the same connector.
If both of these turn out good then most likely the pump is shot. I strongly urge you to do these 2 steps before proceeding.
The link below has about the best prices on OEM stuff. You'll need to send them a message with your VIN to get the correct part number.
http://www.gmpartsdirect.com/ Click on the "customer service" link.
57 Chevy 210
Old 04-25-2012, 11:15 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
777 is correct above - replacing one of these pumps is a messy job and you only want to do it once. Stick with the AC/Delco (Delphi) part, or you will be able to accrue a bit of practice.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-09-2012, 09:06 AM
whateverz whateverz is offline
Delphi pump only replacement is FE0114
I need help with fuel pump alblogg Malibu 7 08-23-2008 03:25 PM
need help with fuel pump epmd106 Caravan | Voyager 2 07-15-2008 03:42 PM
Need help identifing Fuel pump BlazinMlew Blazer 7 03-29-2006 04:18 PM
