Old 04-23-2012, 11:34 AM
jayjp200 jayjp200 is offline
Vacuum in Fuel Tank - 98 ford windstar 3.8 liter
Hello,
Recently few times I have noticed that there is Vacuum in Fuel Tank on my 98 Ford Windstar 3.8 liter.
When ever after driving, I open the fuel cap I hear a hissing sound as if air getting sucked in for 3 seconds.
Is this normal - what can be wrong here?
Please share your thoughts.
Thanks.
Jay
Old 04-23-2012, 11:42 AM
tempfixit tempfixit is offline
Re: Vacuum in Fuel Tank - 98 ford windstar 3.8 liter
Originally Posted by jayjp200 View Post
Hello,
Thanks.
Jay
Is your check engine light on?? ANy codes?? Faulty Gas Cap possibly.
Old 04-24-2012, 08:58 AM
Windstartled Windstartled is offline
I would suspect fuel tank pressure sensor fault. The PCM uses this sensor to vent vapors through the purge valves of the evaporative emissions system.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Old 04-25-2012, 11:31 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I don't think there's anything wrong with it, that's the way the EVAP system was designed and all of my 3 cars do the same if you remove the gas cap right after turning it off.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 04-26-2012, 05:17 PM
The occasional presence of a pressure buildup in the fuel tank at refill time is not abnormal but if it happens consistently it may be a symptom that the PCM is failing to trigger automatic vent due to faulty sensor. One way to confirm this without testing the sensor itself would be inaccurate readings from the fuel gauge but it's not that easy to tell if the gauge is wrong when the discrepancies are minor. Personally I would probe the sensor just to make sure.
98 windstar 3.8 liter - IAC question jayjp200 Windstar 2 09-19-2011 10:07 AM
2000 Ford Windstar - fuel tank display failure & flahing lights & rear heat Fulcrum Windstar 8 05-28-2011 11:31 AM
98 windstar 3.8 liter - P0402 code problem jayjp200 Windstar 4 06-24-2010 08:06 PM
98 windstar 3.8 liter instrument panel lights jayjp200 Windstar 1 02-21-2010 01:06 PM
rear spark plugs 98 windstar 3.8 liter 30fords Windstar 6 04-26-2005 08:24 PM
